Installing Electric Fan In 93 V6 Xle - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-15-2005, 06:42 AM   #1 (permalink)
View bigghek's Photo Gallery
3rd Generation Installing Electric Fan In 93 V6 Xle
I am going to replace my hydraulic fan with an electric fan. Does anyone have any advice on which fan to get and the best way to install the electric fan? I will appreciate all help and comments
bigghek is offline   Reply With Quote
Old 11-15-2005, 08:56 AM   #2 (permalink)
Moving Forward
View Cyorke's Photo Gallery
You should try doing asearch but I dont think it has been done, that I can rememebr seeing on here anyway.
Maybe TOny the Tiger did when he went turbo and all but not sure.
You will need to have a temp sensor to know when to turn it on and all wiring. You need to know the CFM that the fan currently flows so you can match an electric fan to as close as possible to taht.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
Old 11-15-2005, 02:40 PM   #3 (permalink)
TACO FTW
Location: Norton Shores, MI / Houghton, Michigan (MTU) FTMFW
View 92_Gen3_5SFE_LE's Photo Gallery
The hydraulic fan was only in the '92 and '93 V6 Camrys because they didnt have the 1MZ-FE.
The 1MZ-FE has electric fans stock.
92_Gen3_5SFE_LE is offline   Reply With Quote
Old 11-15-2005, 02:50 PM   #4 (permalink)
Moving Forward
I beg to differ. I havea 94 1MZ-Fe Camry and it has the hydraulic fan.
Besides he stated he has a 93 which would fit into waht you sakd anyway.
Chris
Old 11-15-2005, 03:27 PM   #5 (permalink)
I'm a Mac
zoni's Avatar
View zoni's Photo Gallery
hydro is 92-94 3vz and 1mz v6.
Dave Zoni
Latest 3S-GTE Swap Pics
zoni is offline   Reply With Quote
Old 11-15-2005, 03:30 PM   #6 (permalink)
Moving Forward
SO zoni, how would you go about running an electric fan if you were to go this route. What would you use to contro the fan and things of that nature.
Chris
Old 11-15-2005, 03:45 PM   #7 (permalink)
I'm a Mac
zoni's Avatar
i am using an electric fan in my 94 i didnt go this route though. i used a later 1mz PS pump instead of using the 94 1mz pump and plugging it. i didnt get the pump with my motor when i swapped so it was just an easy decision to go this way...
i am using a dual electric low profile FlexALite fan from summitracing.com. I opted to buy the electric fan controller. it is an independant electronic unit that controls the fan on/off. You adjust it with a dial to the desired temperature. it comes with a temp sensor as well.
thats the best thing to do as far as controlling whatever type of electric fan you get. the only other way is a switch that is user controlled, and that can be forgotten and not switched on or forgotten and not switched off and drain your battery.
Dave Zoni
Old 11-15-2005, 03:48 PM   #8 (permalink)
Moving Forward
Cool I figured if anyone ahd done it it was you or Tony. THis should answer all of his questions now.
Chris
Old 11-15-2005, 03:57 PM   #9 (permalink)
I'm a Mac
zoni's Avatar
Tony is using an electric fan as well, and the same rad i have (i stole his idea on the actual radiator). I think his fan is a single fan unit from what i remember. He controls it with his AEM EMS though...
Dave Zoni
Old 11-20-2005, 09:30 AM   #10 (permalink)
thanx for the info
thanx for the info. I was also wondering what would be better a pusher fan or a puller fan. I really dont know which one to use...............
Old 11-20-2005, 02:57 PM   #11 (permalink)
I'm a Mac
zoni's Avatar
that is decided by which side of the radiator the fan is on...
if you plan on getting rid of your a/c, then you can put a pusher fan in front of the radiator, where the a/c condenser is.
if you are keeping the a/c then get a puller fan, cause it has to pull through the rad.
Dave Zoni
