1993 camry missing, after warm-up - Toyota Nation Forum : Toyota Car and Truck Forums
post #1 of 8 Old 11-30-2005, 12:22 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
USA 1993 camry missing, after warm-up
My 1993 camry idles fine during warm-up. But when it reaches operating temperature , it misses . can you help, it is a 4 cyl. Thanks, for any help
onevaldez is offline
post #2 of 8 Old 11-30-2005, 01:32 AM
Local Rape Machine
Quoted: 0 Post(s)
check your timing and plugs and wires
ekim55121 is offline
post #3 of 8 Old 11-30-2005, 01:52 AM
Nad1370's Avatar
Quoted: 0 Post(s)
^^ +1 .
Don't forget to change worn out spark plugs.
Nad1370 is offline
post #4 of 8 Old 11-30-2005, 04:00 AM
Camry Under Construction
05Cam-Weasel's Avatar
Quoted: 0 Post(s)
what do you mean "it misses?"
Weasel(n.)- A naive user, one who deliberately or accidentally does things that are stupid or ill-advised.
05Cam-Weasel is offline
post #5 of 8 Old 11-30-2005, 08:22 AM
Grenaded piston
88 LE's Avatar
Quoted: 2 Post(s)
^ Cylinder or cylinders not firing correctly.
Unplug one of your spark plug wires with the engine running. Then you'll know what missing is.
To explain it in laymens terms:
tick..tick..tick..tick.. (running correctly)
tick...................................tick..tick. .tick.. (missing)
"Skoolin' the unlearned!"
88 LE is offline
post #6 of 8 Old 09-07-2007, 03:05 PM
Quoted: 0 Post(s)
I have one that does this too. Stumbles on acceleration after warm up.
Just had tune up - plugs wires.
I'm going to check the new plug wires with an OHM meter as well as the coil, both primary and secondary hot and cold checks.
FLHTHEMI is offline
post #7 of 8 Old 09-07-2007, 05:08 PM
TN Pussy Man
Eye8Pussies's Avatar
Quoted: 0 Post(s)
iTrader Score: 13 reviews
could be vacuum leak as well if it only does it on idle
HaHa
Eye8Pussies is offline
post #8 of 8 Old 09-07-2007, 05:39 PM
'95 Camry 5S-FE
Quoted: 1 Post(s)
I had that problem. It was the ingnition coil. Because the internal resistance of the coil can vary by heat and the coil in in the dist, right by the engine, is why it only did it when it warmed up. When it was cold (warming up) the coil had a small enough resistance that it worked, but when the engine warmed up it warmed up the coil too, raising the internal resistance and causing a misfire.
All of the lag, none of the boost.
VTEC It's like waiting for really bad sex.
95PimpingCamry is offline
User Tag List
Linear Mode Linear Mode
« Back
