Rear Window wiper '92 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-12-2005, 08:48 PM   #1 (permalink)
TACO FTW
Location: Norton Shores, MI / Houghton, Michigan (MTU) FTMFW
View 92_Gen3_5SFE_LE's Photo Gallery
3rd Generation Rear Window wiper '92
Here in the middle of Michigan we get alot of wet snow.
I was wondering if anyone knew how hard it would be to instal a rear window wiper on my 1992 Sedan?
The wind doesnt blow the snow off and the heaters dont do enough.
Finally, I am not posting this to get a reply of spend 30 sec brushing the snow off.
because that isn't the problem, this snow sticks to the windows as I am driving.
and I do brush my rear window off before I leave my parking spots.
92_Gen3_5SFE_LE is offline   Reply With Quote
Old 12-12-2005, 08:54 PM   #2 (permalink)
View AyzhenInvasion's Photo Gallery
setting one up wouldn't be to hard but gettin it to mount on ur car would be a problem.. cause all you have to have is...
wiper, motor, gears
now you need to find a place to drill a hole for the shaft to go through into the car which has the gear at the end of the shaft (in the car) that mounts to the motor (in the car). and doing it on the window is not something u want to do.. if you see SUV's and how they have the flat glass on the back, they can run the shaft right under the glass on the door part and there would be a motor between the metal part outside and the panel inside.. which has the wiring running up (probably not very hard to do but lots of time and patience)
http://auto.howstuffworks.com/wiper1.htm
you could probably cut out the top (the rear windshield) of ur trunk into like a small triangle and have ur wiper go down into the trunk thru that little hole and have the motor in ur trunk. but then you have to have a way to keep the rain/snow from getting into your trunk
AyzhenInvasion is offline   Reply With Quote
Old 12-12-2005, 09:05 PM   #3 (permalink)
TACO FTW
I guess the place to start is find a car that has a rear wiper and a similarly shaped rear glass.
I think I would drill the hole for the wiper just below the driver side corner of the window.
Old 12-12-2005, 09:08 PM   #4 (permalink)
yeah sorry i was being really stupid..
like he said, hole goes on driver's side, u can check out some sedans with rear windshield wipers and check their positioning and then check up on how ur going to do ur mounts
