1999 Camry CE - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-09-2006, 05:13 PM   #1 (permalink)
View sandslady2's Photo Gallery
1999 Camry CE
Hello, I have a 1999 Camry CE 4 Cyl 5 speed with 87000 miles on it and it has not been wanting to start right away. If I leave my key turned to start and push the clutch in and out a few times it will eventually start. What could this be, starter, clutch?? Sometimes I have to play with the clutch 3 times sometimes 10 and then sometimes the car starts right up when I turn the key. While doing this I hear a clicking noise, just 1 click per try. Please help, I know it is not the battery because all the lights and everything work fine and the battery is only 7 months old. Any info is appreciated.
Thank you!!!
sandslady2 is offline   Reply With Quote
Old 01-09-2006, 07:53 PM   #2 (permalink)
View keithy's Photo Gallery
check your battery terminal connections. If the terminal is not connected tight enough, you sometimes get that kind of respond. Take a rachet and tighten the battery terminal and try start again.
The type of oil you're using soimetimes makes a difference also. depending on the temperature outside, if you use different specs oil, you might encounter harsh start.
Also, another thing that I can think of is your spark plugs. When was the last time you changed your plugs?
keithy is offline   Reply With Quote
1999 Camry CD/CASS Combo, will it work in a 1998? TriumphGT6 3rd & 4th Generation (1992–1996 & 1997–2001) 5 10-26-2005 04:10 PM
1999 Camry has ROT on roof. Gnfanatic 3rd & 4th Generation (1992–1996 & 1997–2001) 11 10-15-2005 12:13 AM
1999 Camry CE wtcnbrwndo4u 3rd & 4th Generation (1992–1996 & 1997–2001) 1 10-12-2005 03:29 PM
