Hitch for a '93 Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-11-2006, 09:36 AM   #1 (permalink)
View Type699's Photo Gallery
3rd Generation Hitch for a '93 Camry
I am going to get a hitch on my Gen3 1993 Camry. There's a bunch of places that install them around here, and I narrowed it down to a couple places. I am looking to tow a 2 place snowmobile trailer with 1 snowmobile on it (probably 700 lbs total sled + trailer). I already have heavy duty brake pads all the way around, new winter tires, and a tranny oil cooler, so it should be up to the task.
Place #1 is the lowest price, and their hitch they use looks nice. They say the factory wiring is more than capable to run the lights on the trailer.
Place #2 is the highest priced, about $100 more than #1. They also say that the Camry's wiring is not adequate for trailer lights, and requires a $100 module that needs to be wired direct to the battery in order to not damage the existing wiring in the car.
I would only be using the trailer maybe 3 or 4 times per year, so does anyone out there have a Gen3 Camry that they have used to tow with and did you have to have the module installed? Or do your lights work just great without it?
My trailer has a couple running lights, I have LED bulbs on all those, so those draw just about nothing. The turn signals on the trailer are standard "1157" bulbs.
Type699 is offline   Reply With Quote
Old 01-11-2006, 04:03 PM   #2 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
you should be fine- especially if you're using LEDs on your car lights
worse come to worste, you can run a wire yourself and use a relay for less than a hundred bucks, but I doubt that would be necessary since the bulbs pull little power
if anything, since you didn't mention that you had a v6, is that you're going to be as slow as hell going uphill with a trailer, people in your car, and a 4banger
HaHa
Old 01-11-2006, 07:01 PM   #3 (permalink)
View dirtdiggler's Photo Gallery
i just saw a wiring kit for your camry on ebay.. seach "camry hitch"..
91 Previa w/275k
07 Mercedes C230 Sport
07 FJ Cruiser
92 Lexus SC400 w/84k
97 Prelude w/86k
dirtdiggler is offline   Reply With Quote
Old 09-18-2006, 07:41 PM   #4 (permalink)
View apz99's Photo Gallery
I had trailer lights without a module on my 92 and the tail light electric system had to be replaced because of them. It worked for a few years though.
apz99 is offline   Reply With Quote
Old 09-18-2006, 07:55 PM   #5 (permalink)
not your average bear
View justchillinjefe's Photo Gallery
I've got a Valley Hitch on my '95 1mz. It has a regular light female end and all the lights on my boat trailer work fine.
I tow a 14 foot hard bottom inflatable with a 50HP motor and the camry pulls like a champ, brakes fine too with stock equip.
I am currently in a similar situation as you, thinking about buying a snowmobile and trailer.
justchillinjefe is offline   Reply With Quote
Old 09-18-2006, 09:42 PM   #6 (permalink)
View toyomoho's Photo Gallery
Having 2ea 1157 bulbs should not be problem for electrical system. If you were to load down the system with too many light bulbs, tail, running and brake lights this can be problem. The manufactures and vendors of these modules have electrical load criteria for usage. Do a web search on this.
The other concern would be the hitch design. Some of these hitches swing low around the muffler causing a decreased ground clearance. The hitch will then hit the ground when going up over curbs and driveways. Might look for a hitch without this bow design around the muffler, have seen them.
Old 09-19-2006, 09:23 AM   #7 (permalink)
My valley hitch has the bow under the muffler and yes it does hit the ground from time to time. It has definately saved my muffler from hitting the ground though . As long as you become more aware of the areas where it bottoms out you will learn how to drive without letting it hit.
Old 09-20-2006, 10:02 PM   #8 (permalink)
View turbo96auto's Photo Gallery
i have a hitch on mine and i pulled a jet ski with stock wiring all the way to ocala from ft lauderdale no problems, however ifyou get on the highway with loads of wind the car may want to kick out of o/d. but it will be fine, is it weld on or bolt on?
96' Camry on 65 shot
May be selling car
has 129k asking 3500 fully loaded, with JVC head unit.
turbo96auto is offline   Reply With Quote
93 camry, spark fuel, timing all god but no fire. Help! SSC 3rd & 4th Generation (1992–1996 & 1997–2001) 1 10-31-2006 11:14 AM
93 camry and 94 engine adroe3 3rd & 4th Generation (1992–1996 & 1997–2001) 3 01-02-2005 06:31 PM
93 Camry Air Conditioning Question pikozz 3rd & 4th Generation (1992–1996 & 1997–2001) 4 10-14-2004 09:29 PM
93 Camry with a few probs GaviN 3rd & 4th Generation (1992–1996 & 1997–2001) 1 03-06-2004 02:43 AM
