power steering fluid change gen3 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-11-2006, 06:46 PM   #1 (permalink)
OMNI's Avatar
View OMNI's Photo Gallery
3rd Generation power steering fluid change gen3
I was doing things according to the thread that was posted for swapping the power steering fluid out of a gen5. the hoses listed in that thread were 3/8 where as mine are 5/8. I stupidly assumed that the connections would the same as the gen 5 post. in other words, no fluid got replaced and I'm pretty sure there is air in the system. can anybody point me in the right direction as to what hose goes where? there are two 5/8 connections to the power steering resevoir facing the timing belt, there are also two 3/8 connections that go to the fan clutch. I hosed and capped the right 5/8 coming out of the fluid resevoir(if your facing the timing belt from pass side) and tapped the steering hose leading to the resevoir and led it to a bucket. after turning the steering wheel, there is no fluid coming out. I just did a valve adjustment and wanted to drive it out tonight. boo hoo! help me please.
hoi hoi
OMNI is offline   Reply With Quote
Old 01-12-2006, 02:16 AM   #2 (permalink)
OMNI's Avatar
uhh, ok. the how to change oil thread gets 89 posts. does anybody know anything about this?
hoi hoi
Old 01-12-2006, 01:26 PM   #3 (permalink)
Darkside Cut Me!!!
Gameroom cash: $127223
View Hajoca's Photo Gallery
That is not simply the fan clutch. Your PS pump runs the rad fan as well.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 01-12-2006, 03:23 PM   #4 (permalink)
OMNI's Avatar
boo man, I thought you had some useful info for the swap.
hoi hoi
Lexus IS Pricing (Canada) lexusis350 Toyota News 28 10-01-2007 12:30 PM
Power steering noise after flushing/changing the steering fluid Camry 2001 Mark22 3rd & 4th Generation (1992–1996 & 1997–2001) 1 12-26-2005 01:34 PM
When to Replace Power Steering Fluid? toylyon Camry & Solara Lounge 10 07-26-2005 09:11 AM
power steering belt removal and crank pulley Q's CrawlingEye Camry & Solara Lounge 1 06-28-2005 05:51 PM
Power Steering Fluid localmotion Camry & Solara Lounge 8 04-01-2005 02:47 PM
