98 Camry decrease in mpg - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-23-2006, 08:10 AM   #1 (permalink)
View Norwalkbob's Photo Gallery
I own a '98 Camry w/ 96,000 mi. Has always got 30-32 mpg. Last 3 tankfuls, dropped to 20 mpg. Tire pressure is o.k. Has never been tuned up, but have not noticed any performance loss (other than gas milage).
Anyone have a suggestion?
Norwalkbob is offline   Reply With Quote
Old 01-23-2006, 08:37 AM   #2 (permalink)
nodrogkam's Avatar
View nodrogkam's Photo Gallery
get that 90K tune up buddy. Its an important one to keep your car running in the future and will more than likely push those mpg numbers back up.
nodrogkam is offline   Reply With Quote
Old 01-23-2006, 01:55 PM   #3 (permalink)
Gameroom cash: $303055
The spark plugs were due to be changed at 60,000 miles. Change those (stick with the recommended NGK's or Denso's) and check/replace the air filter. The timing belt was also due to be changed at 90,000 miles. That needs to be done, but shouldn't effect your fuel mileage. Also, it's time to change out all the fluids (coolant, trans fluid, brake fluid) if you haven't done those yet. Again, these things will effect the longevity of the car, but shouldn't effect fuel mileage.
That said, are you sure about those fuel mileage ratings you gave. I have a 98 Camry XLE 4 cylinder and get about 22 MPG in mostly city/surburban driving. I get about 29-30 for straight highway driving. Those figures go down about 10% this time of the year. That 20 MPG you are getting now seems about right to me for non-highway driving, this time of the year.
Mike
Old 01-24-2006, 10:08 PM   #4 (permalink)
View yz125yamaha10's Photo Gallery
I have a 97 2.2 did the EXACT same thing.First i will say do your tune up then check your milage.After that if it remains roughly the same,replace the coolant temperature sensor. i did that it was like night and day solved my problem.Im guessing its no coincidence, see what happens let me know i would be curious.
yz125yamaha10 is offline   Reply With Quote
Old 01-25-2006, 10:03 AM   #5 (permalink)
95% Biker / 5% Driver
Digger1's Avatar
View Digger1's Photo Gallery
Question
YZ,
If that was the problem, would it show up on the temp gauge? As in showing the coolant temp to be too cold all of the time?
I guess what I'm trying to ask is "Does the coolant temperature sensor send the signal to the temp gauge (on the dash)?
Digger1
"If you don't understand the technology you depend upon, you will someday be a victim of that technology."
Digger1 is offline   Reply With Quote
Old 01-25-2006, 12:31 PM   #6 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
hey, a fellow clevelander! welcome.
just my 2 cents on the issue - im chalking up my poorer gas mileage to colder weather. i drive mainly highway, and during the summer i got a consistant 32mpg. now with the colder weather (and a recent addition addition of a ski rack) im getting about 23mpg.
Old 01-25-2006, 01:49 PM   #7 (permalink)
View mspringer's Photo Gallery
A tune up is a good idea, put probably not causing the significant decrease in mileage.
I would change the O2 sensor(s) as those can degrade significantly, without causing a "check engine light" and cause the car to run rich, affecting mileage.
Also, those are easy to do yourself. (Use "Neverseize" on the threads, just like you would with sparkplugs.)
Parts - you can get the sensors at any autoparts store. I doubt there is any quality difference from OEM, they are all likely made by Bosch.
Also, the parts stores can get O2s with the OEM connector on them, just make sure they are not giving you "universal" sensors - those require the OEM connector to be cut off (sometimes). I don't know costs specifically for the Camry, but other O2s that I have bought in the past were around $50 to $60.
mspringer is offline   Reply With Quote
Some questions - 98 Camry hugo 3rd & 4th Generation (1992–1996 & 1997–2001) 13 01-14-2005 02:31 PM
What OEM radio/cd for '98 Camry bnb1023 Audio, Video, and Security - Tech 0 01-05-2005 10:58 AM
98 Camry sway bars mjh1918 3rd & 4th Generation (1992–1996 & 1997–2001) 2 12-02-2004 01:37 AM
98 camry 5FSE to 3SGTE S13/R32 3rd & 4th Generation (1992–1996 & 1997–2001) 3 11-09-2004 07:56 PM
fitting for struct bar for 98 camry 6cyl toyocamboi 3rd & 4th Generation (1992–1996 & 1997–2001) 9 10-28-2004 10:53 AM
