1996 1mz ecu pinout needed and question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-18-2006, 06:58 AM   #1 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
ok i'm back from vacation now and ready to finsh off my supercharger project. (i know took me long enough) so i'm down now to needing the 2 main parts wireing my smt and the pully bracket. so i'm doing the eaiest 1st.
i need the ecu pinout mainly showing
MAF sensor
cam angle
crank angle
TPS sensor
what also would be nice would be to know where the
ACIS vsv ground wire
O2 sensors
ECT sensor also (no idea why but i can conenct it in)
now my smt can manipulate the signal from only 1 o2 sensor so i was thinking of just cutting like bank 2 sensor compleatly out and only use the modified signal from bank 1 split in to the sensor reading for bank 1 and 2.
Thanks!
^ and leaving it that way!
Old 08-22-2011, 08:33 PM   #2 (permalink)
dorifuto.boi's Avatar
Gameroom cash: $171700
View dorifuto.boi's Photo Gallery
bump. does anyone have a 1mz pinout ?
are the pinouts for the auto/manual and the different years 1mz different ?
http://web.ics.purdue.edu/~dfung/car.html
^^^ List of my mods
dorifuto.boi is offline   Reply With Quote
Old 08-22-2011, 09:13 PM   #3 (permalink)
96 3MZ M/T
chronoti's Avatar
yesish, i know there some thing that can be done on the 97+ ecu that can swap them from at to mt
the 96 mz had a few ecu even tho the es will drive the camry it will not sense right as the the 96 es had the purge valve by the tank, and i believe the mz ecu actually ran through 3 different bus commands for the odb2 (thats counting even tho 94-96 every year had a different ecu code set but the same base command system)
in all the car should run using most any year ecu (i'm not including any vvt-i years) minus one made for the 6 coil pack(94 maybe a few 95). but there will be a few off things.
so in a base recap, 95-01 all the main pins are the same, with a few off here and there. most of the off pins control things we dont care for (well the piggy back doesn't care for)
so i only have the pinout for the 94 ecu, the unneeded one due the the cop system
Old 08-22-2011, 09:34 PM   #4 (permalink)
deng. i wish i could get one for my 99 1mz so i can wire up my piggyback...
plus aem has the ecu extension harness but none for the 1mz........ cause i hate cutting into the stock harness. i was gonna make my own extension harness to cut into but i cant get any of the connectors (the connector that resembles the one on the ecu)
^^^ List of my mods
Old 08-22-2011, 10:16 PM   #5 (permalink)
96 3MZ M/T
chronoti's Avatar
like these?
tyco makes them. i have no idea how i found them, but i got that as a free sample!!!
just search their site for the connector style and you should find what your looking for, i seem to have misplaced my notes......
Old 08-25-2011, 08:24 AM   #6 (permalink)
kinda like those but not exactly.
the one you have in the picture are for boards so the pins come out at a 90 degree angle. i was looking more for the connector where you can push in the pins with a pigtail comming out. the kind of connector im talking about would make it easier to make an ecu extension harness than the connectors made for a board.
if no one has any ideas on how i can make an extension harness, then i may just have to cut into my oem harness...
^^^ List of my mods
Old 08-25-2011, 08:56 AM   #7 (permalink)
actually i might be able to make that style connector work by cutting off the 90 degree leg and soldering the wires onto the legs comming out and heat shrinking them.
but is your connector for the 1mz-fe camry ? looks like its for the 2mz camries and the 2jz mark2/chaser
^^^ List of my mods
Old 08-25-2011, 07:10 PM   #8 (permalink)
96 3MZ M/T
chronoti's Avatar
well that was what i was going to do was solder on the leads coming out of the thing, and yes that one is for the 1mz, well usdm 1mz, find what your pin out style is and search on tyco website you should be able to yours
Old 08-25-2011, 08:09 PM   #9 (permalink)
Bdub215's Avatar
Gameroom cash: $315565
View Bdub215's Photo Gallery
PM Me your Email address. i might be able to help you.
93 Lexus ES300 5spd I/E URSB
Bdub215 is offline   Reply With Quote
Old 08-25-2011, 09:33 PM   #10 (permalink)
thats odd... because on my 99 1mz, this is what the connector on the ECU side looks like........
^^^ List of my mods
Gen4 ECU diagram needed Trdkamuri510 3rd & 4th Generation (1992–1996 & 1997–2001) 5 11-22-2005 09:23 PM
Question: special clamp tool needed for CV boots change? shanzhu1 Camry & Solara Lounge 1 02-28-2005 03:53 PM
ECU question lingo69 Celica Forum 12 11-10-2003 06:09 PM
radiator question....reply needed asap celica/camry Camry & Solara Lounge 2 02-02-2003 08:07 PM
