The radiator support is actually different. The allignment posts on the headlights are in different spots. I purchased some aftermarket angel eye headlamps from a fellow TN member. They fit fine on his 2000 Camry, but did not on my 1997 Camry. So i took my dremel to the radiator support. Bad move.
Didnt realize the lower 3rd bolt on the headlamps has no support to bolt on to. So now they can move somewhat. From what you say, its not a bolt on affair, so i may just need to purchase a 97 radiator support, and just figure out a way to modify it to hold my 00/01 headlamps properly.
I mainly want to do this so i can get some HIDs in the near future. But i would have figured it would have been easy to do the radiator swap. Since its the same chassis, body pieces (mainly the fenders and such) also its the same engine. But hey, if i can gather enough money i might just buy both radiator supports and see what i can do! But that may be unlikely. Ifanybody has some more detailed info on this (cough TRDKamuri cough)
just either send me a PM or post here! Thanks!!
