Gen 3 95 LE Rear Engine Mount - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-20-2006, 09:40 PM   #1 (permalink)
Toyota-Lexus Fanatic
mandyfig's Avatar
View mandyfig's Photo Gallery
3rd Generation Gen 3 95 LE Rear Engine Mount
Gen 3 95 LE Rear Engine Mount, is this a DIY project?
I suspect my thug sound that I hear when I accelerate is coming from a worn out engine mount.
Is this easy to do?
Thanks.
mandyfig is offline   Reply With Quote
Old 03-20-2006, 09:57 PM   #2 (permalink)
View 1shot1kill's Photo Gallery
yeah i gotta replace my front and dog bone mount too. i just ordered them off ebay. so cheap compare to what i had to pay.. yeah thats my question as well. can you DIY?
1shot1kill is offline   Reply With Quote
Old 03-20-2006, 11:08 PM   #3 (permalink)
rusty9's Avatar
Gameroom cash: $387855
View rusty9's Photo Gallery
get the haynes or chiltons repair manual, or download the repair manual thats stickied at the top of the forums. read the procedure and decide for yourself.
rusty9 is offline   Reply With Quote
Old 03-20-2006, 11:50 PM   #4 (permalink)
View Tarzan's Photo Gallery
I had the same problem on my 94. When I hit the gas from a stand still, I would hear a thud. Turns out it was the front engine mount. You can get it from ebay for $20 and do it yourself. Just look at your engine block in front and you will see it.
94 Camry Coupe
Tarzan is offline   Reply With Quote
Old 03-20-2006, 11:56 PM   #5 (permalink)
TN's furry friend
iTrader Score: 17 reviews
View WhiteRabbit's Photo Gallery
does the engine need to be lifted or supported in some way?
WhiteRabbit is offline   Reply With Quote
Old 03-21-2006, 12:01 AM   #6 (permalink)
I'm not sure if you installing the front mount if it has to be lifted. My dog bone mount and front mount were broken and I bought both off of ebay and installed the dogbone one myself. The front mount looked hard because part of the engine acutally sits on it, so I took it to the dealer who installed it for me for $35.
94 Camry Coupe
Old 03-21-2006, 02:26 PM   #7 (permalink)
Breakin' necks since '02!
Durrby's Avatar
iTrader Score: 12 reviews
View Durrby's Photo Gallery
I replaced my dogbone mount once and I supported the engine. I had to have all my mounts beside the tranny mount replaced recently and the shop told me YES the engine needs to be supported. Just have to put a wood block on the the end of the jack and put it under the oil pan.
Bagged 1995 Toyota Camry LE I4 92k
1999 Lexus SC400 153k
Durrby is offline   Reply With Quote
Old 03-21-2006, 09:21 PM   #8 (permalink)
TN's furry friend
yea, im about to replace my dogmount with a polyurethane bushings, the mount seems pretty loose (as in the engine isnt putting any weight on it) and looks like i dont need to support the engine though...
the dogbone just keeps the engine from moving back and forth when accelerating right?
why theyre called engine steady bushings?
Old 03-21-2006, 11:40 PM   #9 (permalink)
mandyfig's Avatar
Dogbone
I replaced mine but did not do anything. Unbolt and Bolted the new one.
I will check the manual.....
Anybody done it?
Could worn rear engine mount cause clutch pedal vibration? blueapple Camry & Solara Lounge 0 01-10-2006 11:11 AM
Transmission mount or Engine mount? slcpunk Camry & Solara Lounge 18 07-04-2004 12:38 PM
Rear Control Arm bushings camry 95 LE burchard 3rd & 4th Generation (1992–1996 & 1997–2001) 0 07-03-2003 08:11 PM
