There is a shifter position switch on teh transmission if I remember correctly. That is probably where your problem is. IF it is jsut a matter of the lights not coming on I dont think I would worry about it much.
Look on the side of the transmission and you should see an arm where the shift cable attaches. There should be some kind of switch located in the same area. You can look for loose connections or maybe oil has gotten on it etc, etc.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
