i've got a lazy downstream o2 sensor, bank 1, sensor 2. i can graph it and it stays around -1 to -2 volts almost a straight line varying only slightly with acceleration. the cat's new. i have no symptoms from this that i can say are directly related. does anyone know if these early narrow band 4 wire heated element sensors have anything to do with the fuel trims or not? the only symptom i think i can attribute to this is the fact it's very hard to get the catalyst system to go ready after a code reset of the ecu.
thanks to anyone who can shed some light on the impacts of this sensor not responding correctly.
thanks
tony
thanks
tony
