If we understand your post correctly, what 88le says is on the money. If its just a little old timing belt cover bolt, you can probly let it go until next time since its hard to get to. Getting a drill in there is no doubt gonna be problematic, but if theres any portion of the old bolt sticking out at all you can hopefully just use small vice grips on it. Or maybe file a small slot in the center of this broken bolt to fit a screwdriver, or file the edges for a wrench.
Id just keep an eye on the cover, make sure the other bolts dont try to loosen themselves out later due to the loss of #4 bolt to hold the cover on. And make sure the cover cant warp up and let dirt in, and that the cover cannot move around and rub on the timing belt. If you want you can seal the timing belt cover edge with some silicone sealant to keep dirt out, ive done that before.
