2000 camry blower motor resistor - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-17-2006, 01:34 PM   #1 (permalink)
View ruoknow's Photo Gallery
Hi guys/gals,
I am in front of a freind's 2000 camry le. the blower only works at the highest setting. After searching a little, I suspect it's the blower motor resistor. I don't know where it is. See the pic I just took. I know which one is blower motor. Could somebody tell me which one is the resistor?
ruoknow is offline   Reply With Quote
The Following User Says Thank You to ruoknow For This Useful Post:
topcat550 (09-08-2011)
Old 04-17-2006, 04:21 PM   #2 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
I suspect it could be the one on the left side of the pic..thats what mine sorta looks like...except the pic doesnt show much detail..so..im only guessing.
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
The Following User Says Thank You to JetspeedCamry For This Useful Post:
Old 04-17-2006, 04:41 PM   #3 (permalink)
thanks
i suspect that one and am not sure too.
Thanks for your help.
Anybody has a clearer idea that us?
Old 04-17-2006, 06:36 PM   #4 (permalink)
View newbie212's Photo Gallery
take the one on the lower left out... 2 screws if I remember correctly.. I was at a junkyard one time getting a blower motor for my 99... I'm pretty sure that that is what it is...
newbie212 is offline   Reply With Quote
The Following User Says Thank You to newbie212 For This Useful Post:
Old 04-17-2006, 07:16 PM   #5 (permalink)
View TRDGen5.5camry's Photo Gallery
the one on bottom left should be it with the 2 screws
TRDGen5.5camry is offline   Reply With Quote
The Following User Says Thank You to TRDGen5.5camry For This Useful Post:
Old 04-17-2006, 07:22 PM   #6 (permalink)
Thank you guys. will get it fixed tonight.
This time I am really confused. See the detached thing. there is no resistors. is this the right thing?
I took some more pics. Anybody can confirm this is the blower motor resistor?
Use this -->
Old 04-17-2006, 11:59 PM   #7 (permalink)
A.J. Subramaniam
View s_ajanthan's Photo Gallery
is this a common problem, myt 2000 camry has the same issue, only the last two speeds work. I don't get low or any of the slower speeds...
s_ajanthan is offline   Reply With Quote
The Following User Says Thank You to s_ajanthan For This Useful Post:
Old 04-18-2006, 01:54 AM   #8 (permalink)
VeeZed
Looks like it to me...different design to my Gen 2 (which uses resitive coils).
Old 04-18-2006, 04:14 AM   #9 (permalink)
View karazy's Photo Gallery
Toyota really screwed that one up. Why they would put an electrical device at the bottom of the blower box, without some kind of moisture proofing is beyond me. Get yourself some dielectric grease (Dow and Corning DC4) and coat all the metal, inside and out.
karazy is offline   Reply With Quote
Old 04-18-2006, 05:59 AM   #10 (permalink)
Tom 2000's Avatar
Gameroom cash: $200700
View Tom 2000's Photo Gallery
That's the part.
I thought Toyota fixed this problem by now, but I guess not.
So far, I had to replace that blower resistor on every Toyota I've owned: '79 Celica, '80 Celica, '88 Camry. I guess it's just a matter of time before I replace it on my 2000.
Tom
2004 Prius Touring Edition
2003 Corolla Luxel
2000 Camry LE - Lunar Mist Metallic
Tom 2000 is offline   Reply With Quote
The Following User Says Thank You to Tom 2000 For This Useful Post:
Old 04-18-2006, 05:11 PM   #11 (permalink)
Gameroom cash: $303055
That should be the resistor. If you are not certain, take it to the Toyota dealer with you and compare it to the new part. I don't think that part is available aftermarket, but I could be wrong. You may want to call around to a few stores like Autozone and ask if it's available.
Mike
The Following User Says Thank You to Mike Gerber For This Useful Post:
Old 04-19-2006, 07:05 PM   #12 (permalink)
Confirmed. That is the right part. cost $28 including tax at dealership. What a cheap fix.
Thanks guys.
Old 04-19-2006, 10:52 PM   #13 (permalink)
A.J. Subramaniam
as far as I know, for the Gen2s, the resistive coils were also cooled by the blower motor so were unlikely to burn out but they were prone to moisture damage... I still think the Gen2 design is leaps and bounds better since I didn't need to replace the coil until 10years into ownership... My Gen4's resisters been like this for 2 years...
Old 06-07-2007, 05:00 PM   #14 (permalink)
View DrXenon's Photo Gallery
I'm confused about where the blower motor is located i.e. which panel do I remove to access it? The factory manual says to remove the glove box but nobody is saying anything about that here.
Is the picture taken from the passenger foot area looking toward the driver's door, or is it looking toward the front of the car?
DrXenon is offline   Reply With Quote
The Following User Says Thank You to DrXenon For This Useful Post:
Old 06-08-2007, 03:36 PM   #15 (permalink)
The big black cylinder shaped thing in the center of the picture is the blower motor.
You remove the panel under the passenger side of the dash.
The picture is taken from the passenger seat floorboard area and looking up and toward the front of the car.
Mike
2000 Camry Maintenance Diy Tips cnn 3rd & 4th Generation (1992–1996 & 1997–2001) 8 10-26-2011 11:04 PM
Need suggestions on new Components for my 2000 camry v6 xxpanipuri 3rd & 4th Generation (1992–1996 & 1997–2001) 2 12-29-2004 04:43 PM
Underdrive Pulley system for 5sfe (2000 camry) cman2000 3rd & 4th Generation (1992–1996 & 1997–2001) 31 12-07-2004 11:35 AM
need advice: what should my next mod be? 2000 camry cman2000 3rd & 4th Generation (1992–1996 & 1997–2001) 17 11-16-2004 10:05 PM
Camry 2000 Hood Latch mkrishna95050 3rd & 4th Generation (1992–1996 & 1997–2001) 0 10-11-2004 07:05 PM
