2000 Camry Vent Mode - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-27-2006, 05:17 PM   #1 (permalink)
View cougar's Photo Gallery
4th Generation 2000 Camry Vent Mode
I have a 2000 camry, 70K miles.
With AC or heater ON, I get air from vents on feet, defrost, and front
vents on the side. No air blows from the front vents in the middle.
It does not matter which option I choose on the vent mode switch (Face,
Face&Feet, Feet, Feet&Defrost, Defrost).
I opened the dash and got the mode switch out. Checked its continuity
as per Chilton's manual, and it is fine.
Does anybody know the continuity tests besides whats already in Chilton's manual?
What else could go wrong that causes this problem?
I have opened most of the dash, but not the top dash. In order to reach the ducts, do I need to open the dash completely?
Chilton's manual does not provide detailed information on reaching the ducts.
Also, with the vent mode switch disconnected (most of the dash is dismantled), I connected the AC switch and the fan switch, then I started the fan, and the air is still blowing on feet, defrost, and front side vents - no air from the front middle vents.
Somebody told me that the damper is not in the correct position.
Is the damper located under the fan assembly (blower) under the dash on the passenger side?
cougar is offline   Reply With Quote
Old 05-01-2006, 12:33 PM   #2 (permalink)
View wtribeflyer's Photo Gallery
No Air From Center Vents
Sorry I don't have an answer for you on your vent problem, but, I do have the exact same issue with my 1997 Camry and would like to know if you find an answer to this problem. On ours, you can look into the center vents with the fan on high and the mode selector set to face and see that there is back pressure blowing on what appears to be a filter or maybe a damper. When you switch the fan off, the pressure that was pushing on the filter or door in the vents goes away. So... is this a filter or a damper?? It does not appear to be accessible. any help would be appreciated. I will let you know if we solve our problem first. Rob
wtribeflyer is offline   Reply With Quote
Old 05-01-2006, 02:03 PM   #3 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
The options are (in order)
Defrost / Def+Foot / Foot / Face+Foot / Face.
I can get the middle dash vents to deliver air on the "foot + Face" and "Face" settings only.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 04-26-2010, 05:26 PM   #4 (permalink)
RyanL's Avatar
View RyanL's Photo Gallery
Hey guys - my brother has a 2000 Camry with this same problem (little/no air comes through the center vents). What did you end up figuring out about it? Does anyone know how to fix this? Thanks in advance!
RyanL is offline   Reply With Quote
2000 Camry Maintenance Diy Tips cnn 3rd & 4th Generation (1992–1996 & 1997–2001) 8 10-26-2011 11:04 PM
Underdrive Pulley system for 5sfe (2000 camry) cman2000 3rd & 4th Generation (1992–1996 & 1997–2001) 31 12-07-2004 11:35 AM
need advice: what should my next mod be? 2000 camry cman2000 3rd & 4th Generation (1992–1996 & 1997–2001) 17 11-16-2004 10:05 PM
Camry 2000 Hood Latch mkrishna95050 3rd & 4th Generation (1992–1996 & 1997–2001) 0 10-11-2004 07:05 PM
92-96 Camry LE HVAC mode (question) 93 Camry LE V6 3rd & 4th Generation (1992–1996 & 1997–2001) 4 10-02-2004 02:44 AM
