93 Camry Wonm't start - Page 2 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-23-2006, 11:41 AM   #16 (permalink)
'93 LE Wagon, V6
View DFBonnett's Photo Gallery
How did you determine you needed an entire distributor?
DFBonnett is offline   Reply With Quote
Old 05-23-2006, 11:55 AM   #17 (permalink)
View fat_bastard's Photo Gallery
Honestly I don't know, I work in the office and the mechanic did it...
fat_bastard is offline   Reply With Quote
Old 05-23-2006, 12:43 PM   #18 (permalink)
mechanic says rotor and cap both look good
Old 05-25-2006, 06:43 PM   #19 (permalink)
View Tarzan's Photo Gallery
http://www.toyotanation.com/forum/t126748.html
94 Camry Coupe
Tarzan is offline   Reply With Quote
Old 07-12-2006, 09:27 PM   #20 (permalink)
95% Biker / 5% Driver
Digger1's Avatar
View Digger1's Photo Gallery
Originally Posted by 88 LE
You need 3 things for combustion. Fuel, spark, and compression.
Air.
Skoolin' the Skooler!
Digger1
"If you don't understand the technology you depend upon, you will someday be a victim of that technology."
Digger1 is offline   Reply With Quote
Old 07-12-2006, 10:28 PM   #21 (permalink)
SE V6 5spd aficionado
mazdaverx7's Avatar
Gameroom cash: $142520
View mazdaverx7's Photo Gallery
my guess is that its the ignitor inside of the distributor. distributors dont go bad very often. trust me, replace the ignitor.
92 Camry SE 3VZ-FE 5spd 131K 6m1
85 Porsche 944 119K 5spd
88 RX-7 10AE 96K 5spd
85 RX-7 GS 5spd
05 RX-8 38K 6spd, 63 Ford Falcon 99K I6 3spd
mazdaverx7 is offline   Reply With Quote
Old 07-12-2006, 10:39 PM   #22 (permalink)
View redleg1one's Photo Gallery
Some what the same way my car died. It was the coil! Runs fine now.
redleg1one is offline   Reply With Quote
Old 08-11-2006, 10:19 PM   #23 (permalink)
Digger1's Avatar
Question
C'mon Fat, fess up!
What was it?
Digger1
Old 08-11-2006, 11:29 PM   #24 (permalink)
View marc780's Photo Gallery
Broken distributor shaft? This actually happened to me on my 88 Nissan truck, check everything even compression, then i took off the dist cap and noticed the rotor spun freely!
The distributor mounting bolts were stripped and not holding the distributor tightly so there must have been enough wobble to break the shaft. Installed heli coil to distributor holes and this so far has worked - the only alternative was replacing the front timing chain cover. Which i will have to do if this problem starts happening again. (Sorry wrong forum for this one lol)
History of the Toyota Camry Ratko Camry & Solara Lounge 54 01-13-2012 08:42 PM
Strange Stalling Problem on 93 Camry 4cyl - Please Advise MSgtVac 3rd & 4th Generation (1992–1996 & 1997–2001) 35 11-02-2008 01:26 PM
93 Camry Wouldn't Start !?! Borisw37 3rd & 4th Generation (1992–1996 & 1997–2001) 18 06-07-2005 10:53 PM
Overheating (again) + sputter start = end of Camry? Redline Camry & Solara Lounge 6 04-20-2005 11:51 PM
Stuffs for my 93 Camry toyotapro 3rd & 4th Generation (1992–1996 & 1997–2001) 4 08-10-2002 10:46 AM
