96 camry oem Mirage Alarm starter killed... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-26-2006, 02:58 PM   #1 (permalink)
View awdark's Photo Gallery
My 96 camry doesn't start at the moment.
It has an I guess stock alarm by mirage. From what I can tell, the starter kill doesn't disarm so I get nothing when I turn the key.
However, the car does start if I hold that little switch (I assume alarm disable) under the lever that pops open the hood. From that I conclude that a relay the alarm turns off for the starter kill is probably broken... Any ideas as to where to check? Or how to test it?
I know the alarm still works because I unhooked the battery and when I reconnected it well... im lucky I didn't bang my head on the hood.
awdark is offline   Reply With Quote
Old 05-30-2006, 02:08 PM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Look under the drivers side dash for a relay thats connected to the alarm.
The relay should only trigger when the alarm is armed and the key is turned to start position.
"Skoolin' the unlearned!"
Old 05-31-2006, 12:51 PM   #3 (permalink)
Ah I was afraid of that. I stuck my head down there and only saw a box that was labled Sensor with a little knob on it. I guess that means my alarm is around there somewhere but will need ltos of dismantling to get to.
Overall Comparison: Toyota Camry XLE V6 v.s. Pontiac Grand P CamryLeb Camry & Solara Lounge 25 08-13-2007 10:55 PM
96 Tacoma Starter Problem Railroader 1st Generation (1995.5–2004) 1 08-16-2005 05:56 PM
96 Camry V6 LE: TRD supercharger? kman10587 3rd & 4th Generation (1992–1996 & 1997–2001) 11 07-16-2004 03:15 PM
96 Camry LE V6 vs 98 Camry XLE V6 2001CamryLE 3rd & 4th Generation (1992–1996 & 1997–2001) 7 05-13-2002 07:53 PM
