Tools and Parts
Just kidding.
I was reading a forum a long time ago (might have been garagejournal), and a wise person said, "A bad craftsman blames his tools. A good craftsman, buys good tools." I'll add to that: "A wise craftsman knows when it's OK to cheap out with Harbor Freight crap." A list of the tools I used for this job that continue to serve me well follows, along with power tools and parts used.
Tools:
- metric socket set. Specifically, a good short socket set with some moderately large sockets (17mm, 19mm, 21mm) such as this:
https://www.amazon.com/gp/product/B000JLBQV2/ref=oh_aui_detailpage_o08_s00?ie=UTF8&psc=1
- deep socket set. I use
https://www.amazon.com/TEKTON-4885-...ON-4885-2-Inch-Impact-6-Point/dp/B000NPUKGQ/ref=cm_cr_arp_d_product_top?ie=UTF8
- crowfoot wrench set. I use
https://www.amazon.com/Neiko-03324A...324A-Crowfoot-Wrench-15-Piece/dp/B000N7DHFK/ref=cm_cr_arp_d_product_top?ie=UTF8
- flex head ratcheting wrenches, at least 12mm. A good set of these will be expensive, check Harbor Freight. I use
https://www.amazon.com/TEKTON-WRN76...4-Flex-Head-Ratcheting-Wrench/dp/B01F512CB8/ref=cm_cr_arp_d_product_top?ie=UTF8
...bought them when they were on sale.
- needlenose pliers
- long needlenose pliers, such as
https://www.amazon.com/Tools-VISE-G...E-GRIP-Pliers-11-Inch-1773583/dp/B0052XQYLY/ref=cm_cr_arp_d_product_top?ie=UTF8
- prybars (two sets handy so you have two of each size). I have a Craftsman set, and this one
https://www.amazon.com/TEKTON-3350-Pry-Bar-5-Piece/dp/B000NPR2YY/ref=cm_cr_arp_d_product_top?ie=UTF8
- seal puller.
https://www.amazon.com/Lisle-56650-...-56650-Adjustable-Seal-Puller/dp/B000JFL83Y/ref=cm_cr_arp_d_product_top?ie=UTF8
- Pitman arm puller. Superior to a "pickle fork," as it has a lower chance of damaging your tie rod end boot. Rent one from your local Autozone or something, I've had bad luck with the Harbor Freight ones. Went through three that bent out on tie rods that the Autozone one never blinked at.
- cheater pipe. Make sure it fits over all your tool handles. 2" pipe, 2 ft and 3 ft long fit over all mine.
- 10mm hex bit socket.
https://www.amazon.com/TEKTON-1363-8-Inch-Socket-Metric/dp/B001NT2LK4
...that set is good but too long for some things. My shorter ones are from Harbor Freight.
- hose pick, I use this set:
https://www.amazon.com/gp/product/B000NPPBQU/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
- Aerokroil or similar penetrating lubricant
- chuck-type stud extractor, I like this one:
https://www.amazon.com/gp/product/B01GKEBG9I/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
- reverse-fluted bolt extractor set, I use this:
https://www.amazon.com/Performance-...ctors-6-Piece-Adapter-1859143/dp/B00LFUTXPM/ref=cm_cr_arp_d_product_top?ie=UTF8
- tap wrench.
https://www.amazon.com/gp/product/B001DZ6YSS/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
- oxygen sensor socket. I use a regular kind instead of offset because you can accurately torque a sensor without having to recalculate the applied torque.
https://www.amazon.com/TEKTON-4929-...TON-4929-8-Inch-Oxygen-Sensor/dp/B000NPUKIE/ref=cm_cr_arp_d_product_top?ie=UTF8
- transmission jack. I bought this one:
http://www.jegs.com/i/JEGS-Performance-Products/555/79012/10002/-1
- engine hoist/shop crane. Mine is from Harbor Freight, do yourself a favor and get a 2-ton model for a bit extra cash (not necessary, just insurance). You can also probably find better quality professional cranes on Craigslist for a good bit less.
- engine sling. I made mine out of Superstrut+chain and bolts/washers from Orchard Supply Hardware.
- 3/8" torque wrench. This will handle most of the torques you need near the middle of its range (most are from 10 to 75 ft-lbs). Mine is from Craftsman and is garbage. You're better off with a Harbor Freight model. If you want to pony up a bit of extra cash, get the Tekton model
https://www.amazon.com/TEKTON-24330...24330-8-Inch-ft-lb-13-6-108-5/dp/B00FMPKAD0/ref=cm_cr_arp_d_product_top?ie=UTF8
...if you really want to pony up cash, get one from SK...theirs are rebranded by Snap-on (with a Snap-on 100% price markup!).
- torque wrench capable of 250 ft-lbs. You need 134 ft-lbs for the subframe, which lands in the middle of the range for something like this:
https://www.amazon.com/dp/B00C5ZL1NS?ref=emc_b_5_t
...Harbor Freight is OK, I use the Tekton and like it.
- straightedge. For measuring torque converter installation distance. This is not a ruler; it is much...straighter. If you are doing a head gasket job sometime, this will come in handy. If not, just use two rulers. I have
https://www.amazon.com/Steel-Straig...ight-Guaranteed-Within-Length/dp/B01DR7T0FI/ref=cm_cr_arp_d_product_top?ie=UTF8
- decent ruler. Used with the straightedge above. Go old-school and get a nice General :smile:.
https://www.amazon.com/General-Tool...ral-Tools-CF667ME-Ultra-Rigid/dp/B00FAU7KIK/ref=cm_cr_arp_d_product_top?ie=UTF8
- transmission funnel. Whatever works for you, the one I use has a long, flexible neck and fits perfectly into the diff fill hole and dipstick tube:
https://www.amazon.com/Lumax-LX-160...3-Plastic-Transmission-Funnel/dp/B00GD2HYQW/ref=cm_cr_arp_d_product_top?ie=UTF8
Power Tools:
I've been very happy with my Milwaukee power tools, and I snap them up whenever they're on sale (Amazon links posted, but I've also bought from CPO Outlets, International Tool, and eBay). I like buying their high-performance FUEL series tools whenever possible (read: on sale. So not down with spending $400 on a tool+battery), I figure the brushless motors and upgraded components are worth it. Since batteries aren't interchangeable you're kind of stuck with a brand once you start collecting power tools, kind of like cameras and lenses. Not all of these are used in this project, just a list with how I've used them.
- 2457-20 Power 3/8" ratchet. Advantage is that it can get where an impact driver cannot. 35 ft-lbs of torque, so a lot of the time you should break a series of bolts loose before going to town on them with this.
https://www.amazon.com/gp/product/B006CSRBTC/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
- 2783-20 Angle grinder, braking. A lot of my Milwaukee tools have rendered my air tools obsolete because they perform just as well and are more convenient, what with the lack of a hose. This one is supposed to stop within 1/2 second of letting the paddle go so you have less of a chance of hurting yourself.
https://www.amazon.com/gp/product/B017Y7VZ8C/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
- Cutting wheels for the grinder.
https://www.amazon.com/gp/product/B01EBDZOFC/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
- 2763-20 High-torque impact wrench. No tool has saved me as much trouble. 700 ft-lbs. Lasts all day on a single 4AH battery. Worth every penny at double the price
https://www.amazon.com/Milwaukee-To...Torque-Impact-Wrench-Friction/dp/B00GFUA6O4/ref=cm_cr_arp_d_product_top?ie=UTF8
- 2604-20 Hammer drill. Works great, is a nice upgrade from my old 9.6V DeWalt. Handle is nice for keeping steady when polishing.
https://www.amazon.com/Milwaukee-26...r-Drill/dp/B007IH6RUK/ref=sr_1_3?ie=UTF8&qid=1485339538&sr=8-3&keywords=2604-20
- 2653-20 Impact driver. An impact driver can't be beat for zipping off large quantities of bolts, nuts, and screws. Watch out because these can round fasteners pretty easily.
https://www.amazon.com/Milwaukee-Im...2653-20/dp/B007WU7VS0/ref=sr_1_1?ie=UTF8&qid=1485339589&sr=8-1&keywords=2653-20
- 2615-20 Right-angle drill. Limited use, I bought it because there was a broken bolt shank where a Camry hood strut attached to the body. Came in handy when I had to drill out a sheared-off bolt at the bottom of the 5S-FE dogbone strut bracket. Saved me from pulling the engine!
https://www.amazon.com/Milwaukee-26...-2615-20-Cordless-Right-Angle/dp/B004M8R9W8/ref=cm_cr_arp_d_product_top?ie=UTF8
- PBT70913 Ratchet pump. So I've gone through at least 5 of those cheapie hand fluid pumps that you screw onto your bottle of gear oil. They always seem to start leaking after a few pumps, my hand gets fatigued, and it doesn't get the last bit in the bottle so I have to take a few bottles and make a gear oil spitoon. I just got this and did three differentials...it works awesome and gets the level in the bottle down a lot farther.
https://www.amazon.com/gp/product/B00CDDBFGU/ref=oh_aui_detailpage_o09_s00?ie=UTF8&psc=1
...these are just what I've been happy with, of course there are other reputable tool brands that will meet your needs.
Parts/Consumables:
DEALER
- 90116-10016 Right side exhaust stay stud. Goes into the front TWC.
- 90179-10128 Nut for above
- 90080-11631 Stud for midpipe to front TWC. If you are replacing all, you need 3. I'm doing 1
- 90080-17187 Locknut for above. Same, need 3, I'm doing 1
- 91512-81035 Bolts (need 2) for midpipe rear flange
- 94180-41000 Locknuts for above. Need 2
- 90430-A0003 Gasket (washer, need 3) for diff fill plug, diff drain plug, trans drain plug
- 00295-00103 FIPG for oil-exposed parts (black). Yeah, you can use Permatex Ultra Black or equivalent, I've just fallen for the Toyota (Threebond) FIPG.
OTHER PARTS
- Fel-Pro MS94976 Gasket, exhaust manifold. Replace if you take the manifold off. Note: what I got was NOT a metal crush gasket, it was composite. Go for a metal gasket if you can, Fel-Pro has a bad habit of giving us cheap composite and paper/fiber gaskets instead of the nice metal ones.
- Fel-Pro 23626 Gasket, midpipe to front TWC. Must be replaced.
- Fel-Pro 23591 Gasket, midpipe to rear/muffler pipe. Must be replaced.
- Beck/Arnley 052-3250 Rear main seal. The hallowed enchirito, as it were. I got the OEM seal in a Beck/Arnley package, $11 on RockAuto. See next entry.
- Fel-Pro BS40427 Rear main seal set. I can't for the life of me find just the paper gasket for the rear main seal carrier. I realized this after I bought the Beck/Arnley part...bought the Fel-Pro set for $17 at AutoZone. I trust the Beck/Arnley oil seal much more than the Fel-Pro (of course, it's OEM!) because I've had a lot of Fel-Pro cam seals start leaking shortly after doing timing belt jobs on our engines. If you're doing this job, you might as well do it completely so get ready to take out the carrier seal it as well.
- Dorman 47021 Oxygen sensor seal. Replace if pre-cat oxygen sensor is removed. Put some copper anti-seize on the shiny side (side that mates to the exhaust. Normally I hate Dorman products (they're shoddy and never fit well) but this was a pleasant exception.
- copper high-temp anti-seize for above. If you buy Denso sensors they come with a little squeezy tube of this stuff. I like
https://www.amazon.com/Loctite-Copp...nti-Seize-degrees-Temperature/dp/B000LDDOXG/ref=cm_cr_arp_d_product_top?ie=UTF8
- Moog K90527 Front sway bar bushings. Make sure you get the right part because the SE and wagon have different size sway bars. These are for a DX sedan.
- Beck/Arnley 1014873 Front sway bar endlinks. If yours are shot, you're rattling up a storm over any bumps, then go ahead and replace them, easy-peasy.
- Teflon plumbing tape. If you wrap it around the sway bar where the bushing holds, it will help with squeaks, especially with polyurethane bushings. I also coat the inside of the bushings with grease. I use the Coastal brake grease they sell at Autozone, and get the plumbing tape at Harbor Freight. 10 rolls for $1.99
http://www.harborfreight.com/12-in-x-43-12-ft-plumbers-thread-seal-tape-10-pk-61377.html
- red Loctite for flexplate bolts, Loctite 271 or 272 are good choices (271 is easily available at AutoZone, etc.; 272 you buy online or at Grainger, etc.). If you get new bolts from Toyota they will come precoated. Some people say you don't need it, just torque to spec and get on with life; but for a few bucks, why not insure yourself against a difficult-to-reach bolt falling out?
- engine assembly lube or something to grease up the RMS and input shaft seal. I use
https://www.amazon.com/Sta-Lube-SL3...33-Anti-Seize-Engine-Assembly/dp/B000CPAWP6/ref=cm_cr_arp_d_product_top?ie=UTF8
- Wix 58998 Transmission screen filter and rubber pan gasket. Just do it. This one says "Made in Taiwan," but other than that looks exactly identical to the OEM one I pulled out.
- transmission fluid. Official spec is Dexron III-compatible fluid, I've used Dexron VI compatible fluid with no ill results thus far. For this, I went with Valvoline MaxLife Dex/Merc (cheaper than the ACDelco Dexron VI I normally use).
- 3/8" transmission hose if you're replacing the oil cooler lines. I bought
https://www.amazon.com/Hayden-Autom...otive-106-Transmission-Cooler/dp/B000HE6H3S/ref=cm_cr_arp_d_product_top?ie=UTF8
...which is just repackaged Gates hose like you get at NAPA or equivalent. I recommend this now:
https://www.amazon.com/Derale-13017...3017-Transmission-Engine-Hose/dp/B004XONNTY/ref=cm_cr_arp_d_product_top?ie=UTF8
- a buddy. Something like
https://www.amazon.com/Giant-Semi-F...Finished-Filler-Cotton-Zipper/dp/B01N2UFE8M/ref=cm_cr_arp_d_product_top?ie=UTF8
...no filler, my ass. They're reselling it as open-box, he's flat because he didn't use jackstands and the car fell (so I returned him). Poor, stupid Paddington.
...I don't have part numbers for the torque converter and input shaft seal. If you want those, just take your old torque converter to Transtar or some other transmission parts warehouse and they will identify it and sell you the right seal.
