Removing fusebox - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-21-2006, 12:06 AM   #1 (permalink)
*Place Title Here*
View Go4shoped's Photo Gallery
4th Generation Removing fusebox
Does anyone know how to move that damned fuse box out of the way so i can get the air duct out of there? I want to put in another tube to make it a cai and maybe deepen the sound a little bit. Heres a pic of the air duct im talking about. i cant figure out which bolts i need to take out. And i suppose there are clips too? Anywho, heres the pic:
Go4shoped is offline   Reply With Quote
Old 07-21-2006, 12:15 PM   #2 (permalink)
trninhds's Avatar
View trninhds's Photo Gallery
there is the black clip under the battery trey, 2 bronze screws that bolts up to the fender, its sandwiched between the box and the fender(can only get in there with a small wrench, 10mm i think but not sure). After you do all that there is a clip towards the back of the box, facing the front windshield. Once you hook that you will be able to push the box down enough to take out the air duct. Its hard to explain but easy to do. It took me a while to figure it out. Hope this helps, if you got any other questions just ask.
trninhds is offline   Reply With Quote
Stuck - removing RH driveaxle from bearing mount awmccready Camry & Solara Lounge 12 04-16-2011 07:53 PM
location of instrument panel fusebox? prcummings 1st Generation (1998-2003) 1 07-06-2006 08:40 PM
removing fusebox, AE92 mrdennmann Archived Corolla threads 6 03-26-2006 12:22 AM
Removing EGR system White89SR5 Archived Corolla threads 1 12-22-2005 12:11 AM
