94 Camry Transmission Clunk - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-21-2006, 10:31 AM   #1 (permalink)
View Rycon's Photo Gallery
Alright my gf bought a 94 Camry (LE i believe) and its a great car, been trying to work on it a little fix some problems here and there. Ive have a Acura Integra and ive done alot of stuff on cars so im not a toal noob .
So i have a question, the car is a automatic (not somthing im used to ) and when you take off, it always makes this strange clunk noise, its not incredibly loud but you can notice it and feel it. It only happens when you take off from a stop or a pretty slow speed. I thought it was happening a certain RPM but im not sure. It almost sounds/feels as if its coming from the bottom of the car, but that doesnt really mean anything. The car runs fine, goes through the gears fine, no other noises. It could also be desribed as a Click. Also, when giving it a good amount of gas (getting the RPM to go up) and then suddenly taking your foot off quickly, the car like jerks, well basicly its not a smooth down shift, as that normal?
Is her tranny going bad?
Oh and what gen is her camry?
Rycon is offline   Reply With Quote
Old 07-21-2006, 09:01 PM   #2 (permalink)
View marc780's Photo Gallery
It could be bad CV drive axles, one way to do a quick check, crawl under and grab the shaft and try to shake it back and forth, feel for a lot of play and noise. Or jack up the front and spin the wheels, while listening. If you find a lot of wear, or a torn cv boot with all the grease vanished from inside the bearing, that might be your answer. But i think theres a good chance it actually is the transmission, i'd take it to a shop for a diagnosis and then myabe to another shop if you have reason not to trust this one - *cough* AAMCO *cough*
Old 07-21-2006, 09:49 PM   #3 (permalink)
View SwampFox's Photo Gallery
Maybe you have a broken motor / transmission mount bushing that lets the motor to move a little on acceleration and then move back the other way on deceleration? Try having someone sit in the car and hold the brake with the car running and shift from drive to reverse while you watch the engine to see if it is moving with the clunk sounds?
SwampFox is offline   Reply With Quote
Old 07-21-2006, 10:38 PM   #4 (permalink)
Well I know the CV boots themselves are fine, and they DO NOT click when turning at all. But it defintly could be what SwampFox said about a broken bushing or some shaft play, il try this stuff out, see what i can come up with, thanx for the suggestions.
Anybody have a Black GEN 3 Camry passenger door handle for sale?
Old 07-30-2006, 08:38 PM   #5 (permalink)
View BumJab's Photo Gallery
Sorry for the hijack...but I have a similar problem.
When sitting in the car with the foot on the brake and shifting from P to R or N to D, I can visibly see the engine move/twist quite a bit. Probably by as much as a couple of inches.
I'm new to auto's too...is this a sign the transmission mount needs replacing or is it normal for the engine to move when engaging a gear?
BumJab is offline   Reply With Quote
Old 07-30-2006, 09:13 PM   #6 (permalink)
bitch please
DarkMastyr's Avatar
View DarkMastyr's Photo Gallery
Just recently had this problem and also thought it might be a transmission issue. Turned out to be a worn dogbone (torque) mount. Easy to replace.
1994 Camry 2.2L LE Auto
DarkMastyr is offline   Reply With Quote
Old 07-30-2006, 10:06 PM   #7 (permalink)
Gameroom cash: $846100
iTrader Score: 13 reviews
View ASG14's Photo Gallery
As most others said, Engine or Tranny mount. My dad had it happen on his old '92 Camry with 60k miles.
'95 Corolla AE101...
Old 07-31-2006, 05:40 PM   #8 (permalink)
SE V6 5spd aficionado
mazdaverx7's Avatar
Gameroom cash: $132020
View mazdaverx7's Photo Gallery
mount for sure. common problem.
92 Camry SE 3VZ-FE 5spd 131K 6m1
85 Porsche 944 119K 5spd
88 RX-7 10AE 96K 5spd
85 RX-7 GS 5spd
05 RX-8 38K 6spd, 63 Ford Falcon 99K I6 3spd
mazdaverx7 is offline   Reply With Quote
Overall Comparison: Toyota Camry XLE V6 v.s. Pontiac Grand P CamryLeb Camry & Solara Lounge 25 08-13-2007 11:55 PM
Official 2007 Toyota Camry Announcement, Images & Specs EKam Toyota News 1481 05-17-2007 10:50 PM
94 camry with 95 camry front bumper and rear trunk/lights? tousi 3rd & 4th Generation (1992–1996 & 1997–2001) 3 11-23-2005 05:55 PM
Transmission failure. Very sad. alchu Camry & Solara Lounge 1 06-14-2004 11:06 AM
