1997 Camry Transmission Fluid Change Question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-02-2006, 10:28 AM   #1 (permalink)
View cyman73's Photo Gallery
Hello all,
Does the 1997 Camry LE 4 cylinder tranny have a transmission filter in it?
I am looking to change the fluid and would like to know if I can just drain and fill or if I have to purchase a filter, new pan gasket...
I will be using Mobil synthetic automatic transmission fluid. Does anyone have a better suggestion?
Thank you very much.
cyman73 is offline   Reply With Quote
Old 08-02-2006, 12:18 PM   #2 (permalink)
View TRD_Rob's Photo Gallery
USA Re: Camry Transmission
Hi:
The transmission does have a filter, you can get the trans kit from toyota. I prefer the Amsoil Synthetic trans fluid. I have since converted the trans to synthetic some 50 K ago, still going strong.
Hope this helps
TRD_Rob
1998 TRD Camry
Injen Air Intake with HKS Filter
HKS Plugs with Vitek Wires
Dynomax Exhaust System
Evans NPG+ Waterless Coolant
TRD_Rob is offline   Reply With Quote
Old 08-02-2006, 12:37 PM   #3 (permalink)
View troydcarothers's Photo Gallery
Have a tranny filter? Absolutely. I drained the fluid from the pan by loosening bolts. Removed pan, gasket and filter, then replaced with new g and f. Filled with new fluid the exact amount drained. Disconnected tranny cooler line and placed into a container, started engine and as dirty fluid from torque converter was being expelled, replaced with new fluid up to full/hot mark on dipstick. Mobil synthetic? Absolutely.
troydcarothers is offline   Reply With Quote
Old 08-02-2006, 12:42 PM   #4 (permalink)
View tarbasd's Photo Gallery
3rd Generation
Yeah, there is a filter, but you don't have to necessarily replace it. Haynes manual suggests to wash it with clean AT fluid and put it back.
You can also just want to do a drain and refill in which case you won't even need a new pan gasket.
tarbasd is offline   Reply With Quote
Old 08-02-2006, 07:47 PM   #5 (permalink)
View kamrhee's Photo Gallery
cyman73, all of the methods mentioned are good. I don't know if this is overkill for you but I installed an in-line transmission filter from Magnafine to filter out fine particles and replace it maybe every 30,000 miles. Cheap insurance.
kamrhee
1998 Camry LE 5s-fe (Stock)
2002 Toyota Highlander 1mz-fe (Stock)
My other car is a Bianchi
kamrhee is offline   Reply With Quote
Old 08-03-2006, 08:34 AM   #6 (permalink)
SE V6 5spd aficionado
mazdaverx7's Avatar
Gameroom cash: $142520
View mazdaverx7's Photo Gallery
definatly replace it. i wouldnt hesitate to replace it while you've got it out. it'll save time and headache in the long run.
92 Camry SE 3VZ-FE 5spd 131K 6m1
85 Porsche 944 119K 5spd
88 RX-7 10AE 96K 5spd
85 RX-7 GS 5spd
05 RX-8 38K 6spd, 63 Ford Falcon 99K I6 3spd
mazdaverx7 is offline   Reply With Quote
Old 08-04-2006, 10:51 AM   #7 (permalink)
Thank you for the good suggestion. I will be calling my local Toyota dealer to get the filter and gasket.
Actually, is there a specific order to tightening the pan bolts? Is there a specific torque for the bolts? I am in the process of buying a Maintenace Manual, so I don't know yet.
Thank you.
Old 08-04-2006, 04:41 PM   #8 (permalink)
3rd Generation
Thank you.
Order: I don't think so.
Torque: Yes.
Old 08-05-2006, 12:44 PM   #9 (permalink)
Gameroom cash: $303055
"Actually, is there a specific order to tightening the pan bolts? Is there a specific torque for the bolts? I am in the process of buying a Maintenace Manual, so I don't know yet."
For the answer to these and many other questions, download the generation 4 manual stickied at the top of the general Camry forum.
Mike
Old 08-12-2009, 10:21 AM   #10 (permalink)
muminiasty's Avatar
View muminiasty's Photo Gallery
Can I get tranny filters in places other than Toyota dealer?? At Toyota they asked me 100$ for the filter is this how much they go for?
muminiasty is offline   Reply With Quote
Old 08-12-2009, 10:41 AM   #11 (permalink)
Gameroom cash: $470955
View carsrus's Photo Gallery
Whoa a 100$?!?!!?
When I went to the dealer ship they said there was no filter on my 98. Turns out there actually wasnt one. I heard theres a strainer in it somewhere or soemthing along that matter.
But 100$ is insane, maybe 30$ tops. I paid like 12$ for the gasket if i remember right.
carsrus is offline   Reply With Quote
Old 08-12-2009, 11:46 AM   #12 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
Check dz63 's DIY.
Also has prices for aftermarket gasket and filter.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 08-12-2009, 11:47 AM   #13 (permalink)
View murphy390's Photo Gallery
97 Camry 4 cyl with 171K miles. Starting at 50K i've drained the pan and refilled with standard Dex/Merc fluid at 10K intervals. Shifts as smoothly as the day I got it.
murphy390 is offline   Reply With Quote
Old 08-12-2009, 08:25 PM   #14 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
The Aisin A140E series transmission uses a strainer. Go to your local parts store and ask to see Fram ATF kit. ~$12 on rockauto.com. They used to come with a cork-rubber gasket. But for some reason no longer shows in picture. That's why I say go to the store to see it.
I order filters (well, strainers really) and gaskets from the local Transtar Industries. Get the cork-rubber, not fiber gasket. Competitive prices but may not be as convenient as your local NAPA, O'Reilly, Autozone, etc etc.
I used Fram beacuse it's a cork-rubber gasket, not some cheap looking recycled crushed tire bits gasket.
http://www.transtar1.com/locations.asp
Also see this DIY:
DIY : Differental Fluid Change
Mobil-1 is a great fluid. For lower cost consider Walmart Mercon V semi-synthetic compatible with Dexron II/III. It's usually a Warren UniLube product, certified by Ford however.
Originally Posted by cyman73 View Post
Hello all,
Old 08-12-2009, 08:25 PM   #15 (permalink)
And this DIY:
DIY: 5S-FE Transmission Fluid & Strainer Replacement Procedure
Official 2007 Toyota Camry Announcement, Images & Specs EKam Toyota News 1481 05-17-2007 09:50 PM
1997 Coolant & Differental question.. NorthernIllinoi Archived Corolla threads 6 10-25-2005 09:03 PM
Damage to 1997 Camry LE chrono807 General Discussion 8 07-28-2004 04:52 PM
How to change Brake Fluid in Gen2 Camry?? smt_007 1st & 2nd Generation (1983–1986 & 1987-1991) 1 11-09-2003 10:14 PM
1997 Toyota Camry Transmission Problem?? Strider 3rd & 4th Generation (1992–1996 & 1997–2001) 1 03-23-2003 01:51 PM
