Some problem with accelerator pedal - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-02-2006, 11:34 PM   #1 (permalink)
tonysun23's Avatar
View tonysun23's Photo Gallery
4th Generation Some problem with accelerator pedal
My 98 CE got some problem with accelerator pedal.
When I stop at red light, when light turns green, I push the pedal, it feels like something is blocking the pedal underneath, it's very hard to push it down. I need to use extra power to push it, then it will release suddenly and go down. After it moves, everything is fine. But when I stop and go again, the problem appears again.
Can anybody tell what this problem is and how to solve it?
tonysun23 is offline   Reply With Quote
Old 08-03-2006, 12:08 AM   #2 (permalink)
touringcamry's Avatar
Gameroom cash: $550225
This is a common problem. You need to clean the throttle body, especially the butterfly valve.
2007 Camry 2.4L 5M
Old 08-03-2006, 05:08 AM   #3 (permalink)
View southpawz's Photo Gallery
Is there a good writeup on cleaning the throttle body on here? Mine is doing the same thing ...I have to give it alittle tap sometimes when taking off from a start so it doesnt look like I am trying to race the person beside me at every stop light when it finally unsticks and I speed off like a bat out of hell....LOL . I just figured it was a bad cable or something.
southpawz is offline   Reply With Quote
Old 08-03-2006, 07:54 AM   #4 (permalink)
View hooRAH's Photo Gallery
There are plenty of people who have posted instructions. If you search for posts by me, I posted some pictures awhile back.
01 BMW 330Ci - 5spd / 93 BMW 525i 5spd-SOLD/ 98 Camry LE
hooRAH is offline   Reply With Quote
Old 08-03-2006, 09:30 AM   #5 (permalink)
View xsnrg's Photo Gallery
It can't be hard...I told a shop that was doing oil changes for me at the time that my pedal was sticking and could he check and clean the throttle body for me and he did it at no charge because he said it only took him like 5 - 10 minutes and some spray cleaner. Hasn't stuck since.
xsnrg is offline   Reply With Quote
Old 08-03-2006, 01:17 PM   #6 (permalink)
Thanks for the info...I will get around to it this weekend hopefully and see how it does
Old 08-04-2006, 02:27 AM   #7 (permalink)
Still confused...
95WhiteCamry's Avatar
iTrader Score: 7 reviews
View 95WhiteCamry's Photo Gallery
The simple way of cleaning it is to remove the air intake hose and get a bottle of carb/throttle body cleaners. Make sure it is sensor-safe. spray at the throttle body and wipe off. Open the butterlfy valve and spray inside, trying to wipe some off as you go along. Just keep spraying and cleaning. For the final step just spray it all the way into the throttle body and then hoook things back up to normal. Starting the car will be hard but once it starts, there should be black smoke coming out of the exaust. That goes to show that you are burning off junk inside your throttle body. Smoke in this case is good. Should help your sticky pedal problem.
"live in the moment, forget the past and ignore the future"
Originally Posted by white3ch0c0late
Yes, Alex is the resident woman-problems guy here at TN... take his advice...
'95 i4 camry sedan -> wrecked june of 2006 by a girl who couldn't drive
'95 v6 camry coupe (dropped, rimmed, front end converted, tinted and debadged) -> current
95WhiteCamry is offline   Reply With Quote
Electric problem! Please help!! 1987SR5 Pre-88 Toyota Pickup/Hilux 2 12-02-2005 09:58 AM
problem with 5th gear (manual) afan Camry & Solara Lounge 6 11-21-2005 10:15 PM
vacuum leak problem...also electrical problem related. afyouthbrigade Camry & Solara Lounge 5 11-03-2005 01:45 PM
QUICK SHIFTER/UNDER PANEL PROBLEM!! & DVD NAVIGATION??!! Rocness81 1st Generation (2003-2008) 6 12-09-2004 10:27 AM
Help! Auto Tranny problem Lilwhite Celica Forum 3 02-14-2004 01:33 PM
