how i resolved P0446 issue - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-03-2006, 07:35 PM   #1 (permalink)
View solidg's Photo Gallery
4th Generation how i resolved P0446 issue
00 camry le v6 101,000 miles
I had been getting the P0446 engine code for some time. I get the code and then i would erase it. The code meand that I need to replace the Vsv for the charcoal canister. The dealer wanted $200 for the labor. The part only costs about $50. I recently erased the code, I have a small code scanner, so its easy for me to do. The week after I drove almost all the time with mt tank on empty. So for about 500 miles the code has not come back. i drove my tank on emoty because I didnt have much money gas is expensive. I didnt think that would effect the check engine light coming on. So today I filled up. Ive driven about 200 miles in the past couple of days with my tank full now. I think maybe by driving with almost no fuel left. That this somehow cause gas from the charcoal canister to be used and that car would no longer give me the p0446 error. I dont know this is just theory. I guess well really have to wait and see in the next couple of weeks to see if the code comes back.
solidg is offline   Reply With Quote
Old 09-17-2006, 06:54 AM   #2 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
bump
found anything new to report?
i do not thikn that it will solve the 446 problem
i have 441 and 446
here is what i have researched
A. Diagnostics for PO441:
1. Remove Vacuum Hoses between EVAP VSV and Charcoal Canister and discard.
2. If there is a metal vapor pipe between EVAP VSV and Charcoal Canister, clean inside of vapor
pipe
3. Replace EVAP VSV and Charcoal Canister assembly with new parts.
4. Install new vacuum hoses between EVAP VSV and Charcoal Canister.
B. Diagnostics for P0446:
1. Inspect vacuum hoses and pipes between EVAP (Purge) VSV and Charcoal Canister for leaks.
2. Replace Vapor Pressure VSV and Canister.
NOTE :When performing diagnostics for an occurrence of a MIL "ON" condition, Diagnostic
Trouble Code (DTC) P0441 may be result of debris in Evaporative Emission Control System. This
may cause blockage of a vapor line, or a stuck VSV, as described in troubleshooting area of Repair
Manual.
skewe is offline   Reply With Quote
Old 09-17-2006, 06:39 PM   #3 (permalink)
my light back on I was wrong. I think I jsut need to replace the vsv. Thats what the toyota delaer said. $200 parts and labor. $50 just for the part. I think I can do the job myself.
Old 02-14-2007, 09:00 AM   #4 (permalink)
View brint's Photo Gallery
446 Error Fix
I had 446 error and spent $450. to fix by changing cannister. Here is low cost solution to problem given by Tototo mechanic.
1. Look for cracked or leaky hoses around cannister.
2. Replace vapor cannister purge valve attached to cannister (about $50.). some dealers will only sell cannister with valve but try others.
3. If error comes back replace cannister ($225).
Mechanic says replacing valve fixes problem 50% of times.
brint is offline   Reply With Quote
Old 07-31-2007, 09:25 PM   #5 (permalink)
View xwildman138x's Photo Gallery
i'm guessing this is a dealer only part? I've been searching the parts websites and nothing. Haven't talked to my parts guy in town yet but I'm thinking its probably dealer only. Is this what you guys had to do is go to the dealer?
xwildman138x is offline   Reply With Quote
Old 07-31-2007, 09:39 PM   #6 (permalink)
DIY : I believe
Maim Menu's Avatar
View Maim Menu's Photo Gallery
Probably a dealer-only part, but it solved my problem. Not a super hard fix either.
Restoring '65 Chevy Impala Super Sport w/ 327-300 small block, Edelbrock carb/intake and T-5 tranny that will probably blow up.
Black '98 Camry LE 4Cyl Auto, 188 000Kms and counting
Black '98 Camry CE 4Cyl Auto, 295 000Kms and counting - SOLD
Maim Menu is offline   Reply With Quote
Old 08-02-2007, 02:04 AM   #7 (permalink)
View chester08's Photo Gallery
In addition to codes P0441& 446.. Look for a disconnectted or damaged hose around the air filter box that goes the evap solenoid, sometimes it's gets knocked off when servicing the air filter with Toyota air filter recharge kits, also solenoid could be failled, the cannister could be breaking down and causing the evap solenoids and valves to stick. can be a trickier system to diag because there are lots of components in the system
good luck and keep us posted
Hope this helped
chester08 is offline   Reply With Quote
Old 08-02-2007, 04:32 AM   #8 (permalink)
had the vsv replaced for the charcoal canister replaced that actually resolved the problem
Old 08-02-2007, 08:15 PM   #9 (permalink)
ordered a vsv online we'll see if it does the trick. Looks like it should according to everybody on here.
CEL - P0446 !!! Help needed megamac83 5th & 6th Generation (2002-2006 & 2007-2011) 49 12-10-2007 08:28 PM
Had an issue with a dealer, need advice. Esco Hardcore Tech and Competition 15 09-09-2007 09:54 PM
2002 Camry soft brake issue Ken4 5th & 6th Generation (2002-2006 & 2007-2011) 7 09-08-2007 07:39 AM
P0441 and P0446 2001 Camry 4 cylinder mnwolftrack 3rd & 4th Generation (1992–1996 & 1997–2001) 3 09-22-2005 06:26 PM
