94 camry w/5sfe leaking coolant into #3 plug area
While driving to myrtle beach last weekend my camry starts miss-firing.When I made it to the beach i started checking the engine out .Pulled plug wires and found small amount coolant in the recessed area for # 3 plug. Dried the area out strarted up fine and ran well till the plug wire became wet. Looked in the plug hole and could se a small leak just above the plug.
I drove the car back home and had to add maybe a 1/2 gallon or water after driving 240 miles
There is no water in the oil or smoke in the exhaust. I am thinking that where the leak is that my head is cracked.
If so doers the leak sealers the are in the parts stores work well ie( blue devil,prestone)
Or with out pulling the head is there anyway without running on 3 cylinders
any thoughts would be appreciated
