1998 Camry jerks slightly when gears shift - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-10-2006, 06:01 PM   #1 (permalink)
View twocamrys's Photo Gallery
Smile 1998 Camry jerks slightly when gears shift
For the past few weeks, my 1998 Camry jerks slightly when the gears shift. (It is a 4 cylinder automatic with 70,000 miles). It doesn't jerk very bad but it is still annoying. I haven't changed the spark plugs before and haven't had a transmission service for several years. Would replacing the spark plugs or transmission fluid help alleviate this problem?
twocamrys is offline   Reply With Quote
Old 08-10-2006, 11:49 PM   #2 (permalink)
Toyota..Moving Forward-->
djarno's Avatar
View djarno's Photo Gallery
If you haven't changed the spark plugs in at least 30,000 miles , I'd recommend you change them but it really depends on what the material your spark plug is made out of(i.e. iridium, copper, platinum). As for the transmission, does it jerk in each gear while you step on the brakes(Besides shifting while driving)?
'95 V6 Camry LE
'04 V8 Tundra
http://www.cardomain.com/ride/2305303
djarno is offline   Reply With Quote
Old 08-10-2006, 11:52 PM   #3 (permalink)
V6LE_CAMRY's Avatar
View V6LE_CAMRY's Photo Gallery
changing transmission fluid should help.
V6LE_CAMRY is offline   Reply With Quote
Overall Comparison: Toyota Camry XLE V6 v.s. Pontiac Grand P CamryLeb Camry & Solara Lounge 25 08-13-2007 10:55 PM
2006 manual shift camry wanted.... MaitreBien 5th & 6th Generation (2002-2006 & 2007-2011) 1 03-17-2006 05:47 PM
Tein S-tech for 1998 camry pk_kk 3rd & 4th Generation (1992–1996 & 1997–2001) 0 03-01-2006 03:25 PM
1998 Toyota Camry sjb5001 3rd & 4th Generation (1992–1996 & 1997–2001) 17 02-18-2006 09:44 PM
1998 Camry Stereo Install ... kungfuSiR 3rd & 4th Generation (1992–1996 & 1997–2001) 5 09-07-2002 01:24 PM
