ok, carpet removed and drying out. removed the rubber tube from ac drain and poked inside wiht a coffee stirrer, must have been a dirt daubers nest, bout a gallon of water came out. reattached the rubber tube and cranked the car. dripping fine underneath car now, but still have some dripping coming from around the fuzzy seal of the heater core, which is disconected from the radiator. I unscrewed and pulled heater core out about 3inches, just enough to see the fins of the core and cranked the car with ac on. still dripped. i changed it over to heat and it blew out lots of water, and didnt stop. when i put back on cold, went back to steady drip. is my heater core bad, or is there probably more water along the lines that will take a while to drain out? would really like to know befor i put back in carpet.
