Oil for 100K+ ?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-14-2006, 08:28 PM   #1 (permalink)
vincentfox's Avatar
View vincentfox's Photo Gallery
Oil for 100K+ ??
1997 Camry LE (4-cyl) with 178,000 miles on it.
Book says 5W-30 I believe. Should I use 20W-50 or something like that for older car?
I live in central valley California so it never gets really cold here, if that's useful.
vincentfox is offline   Reply With Quote
Old 08-14-2006, 08:36 PM   #2 (permalink)
View hassanbigboss's Photo Gallery
I would not recommend 20w-50, it will make your car feel extremely under powered on lower rpm's specially in stop and go traffic. Use 10W-30 OR 10W-40 and it would help with the hig mileage. I do not know how your car has been driven over the time but if the car was driven by a spirited person, going with the thiker oil (10W-30 OR 10W-40) would yield better results. If you see that your car is not burning oil, that would mean that the cylinders are still in good condition and using 5W-30 would be the best preference. If you see that your car is using a quart or two of oil every 3000-5000 miles than the higher viscosity oils will resduce oil consumption.
hassanbigboss is offline   Reply With Quote
Old 08-14-2006, 11:23 PM   #3 (permalink)
Toyota-Lexus Fanatic
mandyfig's Avatar
View mandyfig's Photo Gallery
5W-30 as recommended. Follow it.
mandyfig is offline   Reply With Quote
Old 08-15-2006, 03:00 PM   #4 (permalink)
vincentfox's Avatar
Very helpful thanks!
My old gen-4 seem still in top-shape, I don't recall having to add more than maybe a half-quart between oil changes. I change oil and filter every 3,000-4,000 miles.
Actually recently have thought to start using the Fram "High Mileage" filter and maybe the Mobil-1 Synthetic 5W-30 on it. Want to take good care of ole Betsy since she's been so faithful. That Synthetic oil sure is more expensive than the big blue 5-quart jugs of reguler oil I have been buying at Walmart though.
Old 08-15-2006, 03:46 PM   #5 (permalink)
View toyomoho's Photo Gallery
10W-40 should work just fine with central valley temps. Especially when temps get into the 100’s as they have been.
oil change interval question nomad 2nd Generation (2005+) 15 06-29-2010 10:01 PM
1MZFE engine sludge issue-help okanetoys General Discussion 9 08-06-2006 02:16 AM
Puddle of oil leaking from where? 97&02camryleI4 Camry & Solara Lounge 13 10-31-2004 01:36 PM
? Bad Oil Pump Gen2 1989 2.0L ? mk3glx 1st & 2nd Generation (1983–1986 & 1987-1991) 1 10-21-2004 11:48 AM
Help!! Oil Puddle Under Engine Structureboy Camry & Solara Lounge 12 01-17-2003 01:04 PM
