Thinking about buying 98 camry, need some advice.. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-16-2006, 12:32 PM   #1 (permalink)
View newbie212's Photo Gallery
Saw in my local paper this ad "98 camry le, ran great when parked, wont start, 112k, $700 obo" so i called... I talked to this guy and he told me that the reason the car wont start ( he was told) was because there is a short somewhere in the alarm system....You turn the key and nothing happens. He tried jumping it and nothing happens.. I owned a 97 camry before with the rs3000 security system factory installed and while cleaning the car, i removed my control box from under the seat. I forgot to put it back and my car wouldnt start... Now I know that this persons box is probably still intact but is there anyway to totally disable the alarm with a fuse or something? I am hesitant about buying a car without being able to hear it run and if I can do an easy fix and disable the alarm system completely I'd be a happy camper with a $700 camry... Any advice would be appreciated.. Thanks
newbie212 is offline   Reply With Quote
Old 08-16-2006, 12:41 PM   #2 (permalink)
Ninja-rator
RningOnFumes's Avatar
Gameroom cash: $396985
View RningOnFumes's Photo Gallery
you could try diableing it by depressing the valet switch which can usually be fourn on the driver's side kick panel. Turn key to on, Press it, wait for a beep and start the car.
**ADAM! A/C button for Gen 5.5 Camry (2005 LE) !! Por favor!
Brake lights aren't broken, I just don't brake.
--Can honestly go to a parts counter and ask for brake shoes for the front brakes.
--Likes long walks on the beach.... once it's lit by a massive bonfire.
RningOnFumes is offline   Reply With Quote
Old 08-16-2006, 03:18 PM   #3 (permalink)
SE V6 5spd aficionado
mazdaverx7's Avatar
Gameroom cash: $142520
View mazdaverx7's Photo Gallery
a lot of times, just removing the alarm is the best way. almost all alarm control boxes are mounted under teh dash, near the steering shaft. you can unplug the main control box and trace every wire and disconnect it. for $700, you cant go wrong.
92 Camry SE 3VZ-FE 5spd 131K 6m1
85 Porsche 944 119K 5spd
88 RX-7 10AE 96K 5spd
85 RX-7 GS 5spd
05 RX-8 38K 6spd, 63 Ford Falcon 99K I6 3spd
mazdaverx7 is offline   Reply With Quote
Old 08-16-2006, 03:36 PM   #4 (permalink)
Gen 4 XLE v6
jhbhatia's Avatar
View jhbhatia's Photo Gallery
for $700 its a steal. Go grab em
Desi Toyota Dude Here!!!
jhbhatia is offline   Reply With Quote
Old 08-16-2006, 03:49 PM   #5 (permalink)
Super Moderator
eyeball96's Avatar
Gameroom cash: $906227
iTrader Score: 59 reviews
700 bucks for a 98, I'd tow it home for that....The current owner will freak tho if you remove the kick panel, push a button, it starts, and you drive away!.....Be sure to take a pic of the look on his face if that happens!
96 Camry Coupe LE V6
98 Honda CRV
08 GMC Crew
11 Kia Sportage EX AWD
Old 08-17-2006, 02:32 AM   #6 (permalink)
View marc780's Photo Gallery
Newbie, shh, Find the alarm and cut the wires. It will probly be the cleanest part under the hood - and will look like the add on that it is!
Then change the battery. maybe the alarm is draining it. $700= a good deal if the car is otherwise good!
The guy is frustrated and just wants to dump it. so take advantage of it - i would!
doesnt sound a hard issue to fix, theres a power drain and not hard to fix. if you need additional help post here or im me.
Old 08-17-2006, 09:57 AM   #7 (permalink)
02
JMSinMD's Avatar
View JMSinMD's Photo Gallery
Suggestion
Ask him if he'll take $500, the cost of towing and possibly taking it to a junkyard will make up the difference , if he says no still buy it. You can throw it on ebay and get more for it, if you can't get it to work.
JMSinMD is offline   Reply With Quote
Need Help!! Removing Front Door Panel 98 Camry sk72 3rd & 4th Generation (1992–1996 & 1997–2001) 0 01-06-2006 02:51 PM
need advice about 1998 Camry CE joy603 3rd & 4th Generation (1992–1996 & 1997–2001) 2 09-21-2005 11:17 PM
Advice on buying an 86 Camry 86Camry 1st & 2nd Generation (1983–1986 & 1987-1991) 7 09-15-2005 11:50 AM
buying used camry psully Camry & Solara Lounge 1 08-12-2004 11:43 PM
