Seafoam vs Marvel Mystery Oil - Toyota Nation Forum : Toyota Car and Truck Forums
post #1 of 20 Old 08-20-2006, 11:15 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I see alot of threads about Seafoam. It sounds like it is used exactly the same way as Marvel Mystery Oil. I have always used Marvel Mystery Oil in the past.
Is Seafoam any better?
Dave G is offline
post #2 of 20 Old 08-20-2006, 11:11 PM
Senior TN Member
Quoted: 2 Post(s)
They are different. Marvel mystery oil was invented in the days when upper cylinder lubrication was a real problem. And "back in the day" means the 1920's here.
Nothing wrong with it i guess, i have used it in gas and oil from time to time, personally, i've never noticed any type of performance difference whether i used it or not. i dont believe you can go wrong using it but modern oil and gas does pretty much anything marvel could do, IMO.
Seafoam is a pretty good cleaning product for removing carbon, deep creep spray does a fine job when cleaning the TBI butterfly and IAC and is also a good general lube. It is pricey but i often do buy it because it seems to work. The bottled kind is good to dump in the tank once in a while but if you notice a difference, as with any other additive, soemthing may be wrong with your engine.
marc780 is offline
post #3 of 20 Old 08-20-2006, 11:26 PM
touringcamry's Avatar
Quoted: 3 Post(s)
I just ran Seafoam through the throttle body today. Difference was very minimal, or could just be placebo effect. I guess it cleaned what ever it was supposed to, judging by the amount of smoke that came out. Either that or that was the product being vaporized or burned.
This is 15 screen captures from the video clip of me starting the car after running Seafoam through it.
And this is the video: http://rapidshare.de/files/30160969/seafoam.mpg.html
2007 Camry 2.4L 5M
touringcamry is offline
post #4 of 20 Old 08-21-2006, 11:55 AM
Senior TN Member
Quoted: 2 Post(s)
lol touring.
Heres my opinion on all this, the reason there are so many posts on seafoam and cleaning the TBI and IAC is because it is one of the few genuine problem issues with our Camrys. Toyota designed the engines so the PCV gases (sorry for all the acronyms oy) go straight into the plenum. And after many miles there is buildup but usually does not do much harm for a long time. Modern engines run hot enough to burn away the effects from any problem areas including piston tops and valves, with one exception, yep the throttle body butterfly and Idle Air Control valve.
There are several easy solutions and none take much work or have to be done very often.
1. Per other peoples posts - you can simply cut the hose between the PCV valve and plenum, and install a clear universal fuel filter which cost about $3.00 plus a couple hoses clamps. (Ifyour engine idle funny after this maybe you pointed the filter arrow the wrong way, lol, gozinta engine.) And this will catch most of it.
2. If you remove the plenum for other maintenance, such as cylinder head or manifold work etc., then and only then soak it but good the inside with seafoam or carb cleaner and roto rooter it with paper towels, gun patches, what have you. Just get it as clean as you can and then forget it. Personally i wouldnt remove the plenum just for this cleaning, i dont believe its necessary.
3. Clean the TBI butterfly and IAC. (Dirty IAC shown in image above)
(If you use the fuel filter trick, the need for this ought to be minimal.) But after about 40 or 50k it will probably need it - and your idle might one day start to get rough and you will wonder why, and so you might wind up spending $$$ to find out when the only problem could be, dirty TBI/IAC. And the mechanics you take it to will no doubt, be very glad to take your money to fix it, when meanwhile, maybe all you needed was a $5 can of intake cleaner and a screwdriver to remove the big hose clamp off air filter tube and clean this thing.
marc780 is offline
post #5 of 20 Old 08-23-2006, 01:00 AM
Quoted: 0 Post(s)
What is the IAC?????
MAXIMUS1968 is offline
post #6 of 20 Old 08-23-2006, 01:08 AM
Senior TN Member
nodrogkam's Avatar
Quoted: 1 Post(s)
lol touring...mine was so much worse. lol
nodrogkam is offline
post #7 of 20 Old 08-23-2006, 01:51 AM
Quoted: 3 Post(s)
IAC is idle air control
nodrogkam: Your car is two years older than mine.
2007 Camry 2.4L 5M
post #8 of 20 Old 08-23-2006, 09:46 AM
Senior TN Member
nodrogkam's Avatar
Quoted: 1 Post(s)
yeah thats right u have a gen 4.5
anyways im curious, did you just pour seafoam into your tb after taking off the intake pipe?
I did seafoam through the brake booster/crank/gas.
post #9 of 20 Old 08-27-2006, 09:57 PM
Senior TN Member
nodrogkam's Avatar
Quoted: 1 Post(s)
http://s22.photobucket.com/albums/b3...nt=Seafoam.flv
well...this is like the 3rd treatment of seafoam i have put my car through. last treatment was about 10K ago i guess. SAD how bad it got...and i over maintain my car as is.
post #10 of 20 Old 08-27-2006, 10:31 PM
Senior TN Member
Quoted: 2 Post(s)
Idle air control valve, bottom of image - it has small vanes inside about the size and shape of two razor blades. These vanes are supposed to be closed when engine is cold and then they rotate to allow more air into the engine as it warms up. PCV gas crud builds up on them, which if ignored long enough, closes the air space and often this is a cause of rough idle on high mileage engines, if not cleaned every 40,000 or 50,000 miles. A good soaking with Carb cleaner through its air hole in TB assembly should be done while cleaning the TBI butterfly, and this is often sufficient to do the job. And if not, then and only then is it time to disassemble for a better cleaning.
marc780 is offline
post #11 of 20 Old 08-27-2006, 10:48 PM
Quoted: 3 Post(s)
I poured some in a glass jar and then I took the brake booster vacuum line off and let it suck the stuff in and let it sit.
I poured maybe 2 - 3 oz in with the oil and none in the gas.
2007 Camry 2.4L 5M
post #12 of 20 Old 08-27-2006, 10:51 PM
Senior TN Member
nodrogkam's Avatar
Quoted: 1 Post(s)
yep me too. cept i just cut a waterbottle in half.
anyways i should be all good once again. finally used tb cleaner too. im just curious why after so little time and mileage it smokes so much already.
i should meet you one day. im going down to Irvine soon for college.
post #13 of 20 Old 08-28-2006, 08:45 PM
Quoted: 0 Post(s)
Smoke comes from the Seafoam or whatever fluid you're runing through the engine via air intake ... just put a couple drops of seafoam on the engine block while hot; you'll get some smoke. No problem, just the nature of the game.
jbrams is offline
post #14 of 20 Old 08-29-2006, 07:31 PM
Quoted: 0 Post(s)
I was at the local NAPA store to buy Seafoam last night and the sales guy mentioned that it may or may not cause problems for the cat converter. Just wondering if anyone had any issues with their cat converter after seafoaming?
ganey is offline
post #15 of 20 Old 08-29-2006, 07:44 PM
NYR
Quoted: 0 Post(s)
Believe it or not, I screwed up my IAC by trying to clean it. Carb cleaner/throttlebody cleaner can fuck up a perfectly good IAC. The internals of the IAC/ISC are sensitive to the stuff....trust me!!
Ive asked many a mechanic about this and they pretty much told me that the Japanese IAC's are more sensitive then the Ford or GM ones. When I cleaned the IAC in my former Mercury Grand Marquis, it did not screw it up, but the one in my Camry got destroyed when I sprayed throttle body cleaner into it!
'00 Solara SE V6, 5 speed
Formers:
'90, '88, '96, '95 Camry, 5 speeds
'99 Solara SE V6, 5 speed
IvanHoe is offline
User Tag List
Linear Mode Linear Mode
« Back
