ABS light on, code 36, 71 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-20-2006, 10:28 AM   #1 (permalink)
bronzemaxell's Avatar
Gameroom cash: $270360
View bronzemaxell's Photo Gallery
a while ago, i was making a u turn, then my 94 v6 camry abs light came on, not suspension work related
today, i had a chance to follow the service manual, removed short pin, jumped TC to E1 in DLC1, and initially i found the abs light flashes 11, 31, 36, 37. i also proceeded to check speed sensor signal jumping TS to E1, and after driving it at 40mph, the code returned is 71.
according to the diagnostic trouble code chart
11 = open circuit in ABS control(solenoid) relay circuit
31 = right front wheel speed sensor signal malfuction
36 = Open circuit in right front or left frear speed sensor circuit
37 = Faulty rear speed sensor rotor
71 = Low output voltage of right front speed sensor.
i also tried to clear the code by pressing brake pedal 8 or 10 times within 3 seconds.
now i am left with code 36, rest of the codes are gone, and i also check the speed sensor signal again, and code 71 still there.
any expert out there, with abs code 36 and 71, should i check the abs sensor wiring on my right front first, or just proceed buying a new $100 abs sensor,
low output voltage on speed sensor mean sensor is bad? or just because bad wire open circuit?
thanks
bronzemaxell is offline   Reply With Quote
Consumer Reports on HID Phi General Discussion 28 01-17-2007 08:23 PM
Code 71 Issue????? rfich53 Archived Corolla threads 0 08-13-2006 08:41 PM
CORRECTION: Code 71 Question rfich53 Archived Corolla threads 6 08-02-2006 02:14 PM
Code 71 & Fuel Filter Questions leeave96 Tercel, Paseo, Starlet, and Sera Forum 2 11-19-2005 08:39 AM
Interior Light, Airbag & ABS Light Nothing Work!!!! 94_v6_camry Camry & Solara Lounge 8 05-14-2005 01:15 AM
