Weird AC Problem possible bad AC Switch? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-27-2006, 03:29 PM   #1 (permalink)
View jiggy2dmax's Photo Gallery
Well although its the end of the summer, I seem to have a weird problem with my AC. Im not sure if it just needs freon or if its a larger problem. THe AC blows only warm air. However, the AC switch does not seem to work either. If I push it in, it does light green and i would usually be able to hear the AC compressor kick in. Could the AC Switch cause this problem or does it just need freon? Thanx in advance guys.
jiggy2dmax is offline   Reply With Quote
Old 08-27-2006, 04:55 PM   #2 (permalink)
View toyomoho's Photo Gallery
If the Freon were too low, the A/C pressure switch would prevent the compressor from kicking in when the console switch was engaged. It could be the Freon is just low. There may be a sight glass near the A/C dryer. This is viewing port allowing you to see the Freon circulate. Start the A/C; look for bubbles in the fluid as it circulates (compressor on). If yes, the Freon may be low. PS: there will always be bubbles forming in the Freon when the A/C (compressor) has just turned off. Might also be the evaporator temp switch.
Old 08-23-2009, 03:47 PM   #3 (permalink)
'07 Camry SE V6 AT User
WiggyFife's Avatar
View WiggyFife's Photo Gallery
Gen6
I have posted a similar issue to this for my 07 Camry SE, in the Gen 5 & 6 Subforum. Do you recall hearing of this issue for the 07 Camry's??? Thanks!!!
Aloe Green Pearl w/ Options FE, EJ, RF, SR, CF, V4, V5, EF. OTD Price= $25,594 (before TTL & Doc Fees). U.S.-Built in 08/06.
WiggyFife is offline   Reply With Quote
Old 08-23-2009, 06:49 PM   #4 (permalink)
View skuttduck's Photo Gallery
My 2000 Camry did this last year, and I had to put 2 cans of Freon in it. By the way, my 2000 Camry does have the sight glass. My co-worker has a 95 Camry and his does not have the sight glass, but also needed some refrigerant.
The sightglass is on the very front of the car in front of the radiator and just behind the bumper.
If you need to charge it, it is on the low side, which is right up next to the passenger side near the firewall.
skuttduck is offline   Reply With Quote
Old 08-23-2009, 06:59 PM   #5 (permalink)
Slowly learning....
View Retrospekt's Photo Gallery
It's not the switch. As was said already, the compressor will not switch on if Freeon levels are too low.
Buy some cans of Freeon (R134A) + Oil + Leak Sealer at walmart. The big ones should come with a gauge, which you can swap. Buy 1 big one and 3 small ones, that should be enough to get enough in to be in the "normal" range.
Just keep in mind that adding Freeon does not gaurantee it will work. If you have a large leak all that Freeon will escape again and you just lost 40 or more dollars.
1996 Toyota Camry | 4 Cyl. 2.2L | Black Paint with Tan Interior | All Stock | DEAD at 155k. Broken Crankshaft/Main Bearing
Retrospekt is offline   Reply With Quote
help weird problem james399 Camry & Solara Lounge 17 01-31-2006 08:49 PM
Weird Window Problem..... stir_fry_boy Archived Corolla threads 9 11-29-2005 09:59 PM
Aftermarket FOG LIGHT SWITCH WIRING PROBLEM...2002 Tundra SR5 garzee13 1st Generation (2000–2006) 3 11-24-2005 05:58 AM
WEIRD Starter Problem!! HELP ME Please!!! 89_3SFE Celica Forum 2 09-14-2004 09:32 AM
1990 V6 Bad Cold Run Problem jtorbitt 1st & 2nd Generation (1983–1986 & 1987-1991) 2 09-30-2003 08:23 PM
