2007 Camry 16" Wheels on a 1998 4th Gen? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-28-2006, 08:33 AM   #1 (permalink)
momotaro's Avatar
View momotaro's Photo Gallery
4th Generation 2007 Camry 16" Wheels on a 1998 4th Gen?
I did a search but turned up empty.
Does anyone know if the 2007 Camry 16" wheels will fit on my 1998 Camry?
Thanks!
momotaro is offline   Reply With Quote
Old 08-28-2006, 08:58 AM   #2 (permalink)
touringcamry's Avatar
Gameroom cash: $550225
The bolt pattern should be ok, but you will probably need spacers.
2007 Camry 2.4L 5M
Old 08-28-2006, 10:24 AM   #3 (permalink)
2GR FTW
darksparkz's Avatar
View darksparkz's Photo Gallery
What are the exact specs on the 16" wheels? I doubt you need spacers unless they were wider then 215 or 225.
2007 Toyota Camry SE 2GR-FE
Retrofit TSX HID Projectors | TRD Lowering Springs | Smoked LED Tails | Custom Apexi WS2 Catback Exhaust | BlueBatMobile Eyelids| UR Front Strut Bar | UR 23mm Rear Sway Bar | K&N Short Ram Intake| Kenwood DNX8120 In-dash | Lexus IS350 18" Wheels | Toyota Japan JDM Vent Visors | IS-F Black Leather Shift Knob
Other cars: F20C (AP1) | 2JZ-GE (JCE10)
darksparkz is offline   Reply With Quote
Old 08-28-2006, 11:21 AM   #4 (permalink)
momotaro's Avatar
Thanks for posting your replies so quick!
The tires are 215/60 R16.
The only problem I see now is the overall diameter is too big.
I guess I could go with a shorter sidewall...
Thanks again!
Old 08-28-2006, 11:54 AM   #5 (permalink)
Gameroom cash: $152705
View redgtxdi's Photo Gallery
This thread DEMANDS a "photochop" of a Gen 4 wearin' Gen 6 rims............ASAP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!
redgtxdi is offline   Reply With Quote
Old 08-28-2006, 12:30 PM   #6 (permalink)
2GR FTW
darksparkz's Avatar
According to http://www.discounttire.com/dtcs/infoTireMath.dos
There's only .67" difference in diameter. I think it might just be fine without rubbing. But to be on the safer side, I guess going with 215/55 is a better idea.
Old 08-28-2006, 12:45 PM   #7 (permalink)
momotaro's Avatar
Wow, thanks for the heads up.
I did a calculation on miata.net's tire calculator but I must've input some wrong info.
Hmmm, looks like I may do this afterall.
EDIT: Arrgghhh, they're already sold. I guess you snooze you lose!
Toyota's Globalization Takes Shape through the Camry 2007CamryXLE 5th & 6th Generation (2002-2006 & 2007-2011) 1 08-19-2006 06:52 PM
Compare: 2007 Honda Accord Pics...Yay! or Nay? vs. Gen 6 Camry LunarMist 5th & 6th Generation (2002-2006 & 2007-2011) 53 06-19-2006 11:27 AM
2005 Avalon wheels on Gen 3 Camry gszczyrb 3rd & 4th Generation (1992–1996 & 1997–2001) 1 07-21-2005 07:15 AM
Quote for 4 rebuild OEM Gen. 4 Camry wheels - $1,150 kenratboy Camry & Solara Lounge 1 10-25-2003 07:02 PM
