*Help - Chaning brake pads - No anti squeal springs??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-31-2006, 07:36 PM   #1 (permalink)
View meddotnet's Photo Gallery
meddotnet is offline   Reply With Quote
Old 08-31-2006, 08:18 PM   #2 (permalink)
Toyota-Lexus Fanatic
mandyfig's Avatar
View mandyfig's Photo Gallery
Anti Squeal springs will help, hence it was designed in. Return and get ones with the springs.
mandyfig is offline   Reply With Quote
Old 08-31-2006, 10:01 PM   #3 (permalink)
Gameroom cash: $152705
View redgtxdi's Photo Gallery
Dunno about the springs.
Just did a brake job on my '95 Prizm and *those* pads *did* have the holes, but there were no springs & I wasn't about to go shopping for any so I just put the pads in & used a lot of blue gunk between the shims & pads as well as greasing the sliders, etc. really well. Seems to be fine.
Now, my '98 Camry *does* have the springs and I'm gonna make sure I NEVER lose them.
I *do* tihnk that it makes a difference, but I also know that my Prizm brakes are working just fine without them.
redgtxdi is offline   Reply With Quote
Old 08-31-2006, 10:20 PM   #4 (permalink)
not actual size
brink's Avatar
View brink's Photo Gallery
fwiw, you can get replacement springs from a dealership for about 4 bucks.
Having said that, I drove without them on one side for several months and noticed no excess wear or noise. Course it was only 4 months.
If the slider pins are moving normally and you put antisqueel gunk on the pads, I'm thinking you should probablybe okay.
-- Jonathan W.
http://fleshy.org.nz/
brink is offline   Reply With Quote
Old 09-01-2006, 11:38 AM   #5 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
man, mine do have the springs and they still squeal like a girl on prom night.
Old 09-01-2006, 02:47 PM   #6 (permalink)
Gameroom cash: $303055
Those springs (I think you mean shims) are there just to reduce the noise caused by pad vibration. They will not effect braking performance. You can get them at thew dealer and put them on or you can use spray or finger applied "disc brake quiet" on the backs of the pads as someone above suggested. Or you can just drive the car for a while and see if you notice any noise. If you do, then you can do one of the above 2 things to eliminate the noise.
Mike
Old 09-01-2006, 10:05 PM   #7 (permalink)
Old 09-01-2006, 10:27 PM   #8 (permalink)
Old 09-02-2006, 12:31 PM   #9 (permalink)
5SFE
Lord_Anarchy's Avatar
View Lord_Anarchy's Photo Gallery
Did you bleed the brake system after you pushed in the caliper to fit the new, thicker pads? A longer throw on the pedal, to me, sounds like air in the system.
Lord_Anarchy is offline   Reply With Quote
Old 09-02-2006, 11:34 PM   #10 (permalink)
95% Biker / 5% Driver
Digger1's Avatar
View Digger1's Photo Gallery
Exclamation
Mike
Mike,
IMMSMC, he really is talking about springs. I don't believe the 6 cylinder Gen 4 has these springs, but my car does (see signature).
Digger1
"If you don't understand the technology you depend upon, you will someday be a victim of that technology."
Digger1 is offline   Reply With Quote
Old 09-02-2006, 11:37 PM   #11 (permalink)
Digger1's Avatar
Question
Originally Posted by meddotnet
I simply got other pads from somewhere else which did have those holes in them and they work fine now. Thanks for you help.
I do have one more question,
After I changed the brake pads, now I have to press the pedal lower to brake. Otherwise everything else is fine. While I was pushing the piston in for the new pads, some oil had leaked out from the rubber around the piston.
Is this bad? what should I do?
Med,
It may be time for a slave cylinder rebuild/replacement. Has the brake fluid ever been changed in this car? Brake fluid that is really old and dirty can hold a lot of moisture. Moisture = corrosion.
I change my brake fluid every 30K miles.
Digger1
Old 09-03-2006, 11:44 AM   #12 (permalink)
Gameroom cash: $133300
View profuse007's Photo Gallery
anti-squeal spring aint gonna help if your caliper rail is seizing up. clean and relube, very important procedure.
2009 Camry SE || Techstream V.6.0 with Openport 2.0 || TSX 4300K Denso
Houston-TX: need key chip, remote, or body features programming? PM me.
profuse007 is offline   Reply With Quote
Brand new brake pads, brake pedal still bottoms out!! izekat Tercel, Paseo, Starlet, and Sera Forum 6 06-26-2005 11:35 AM
SW20 brakes for the do-it-yourselfer ... KAOS MR2 Forum 11 09-18-2004 01:21 AM
Anti-squeal on brake pads... 97&02camryleI4 Camry & Solara Lounge 10 06-25-2004 12:01 AM
New Brake Pads ! Lychee Camry & Solara Lounge 0 10-31-2003 03:23 PM
