Replacing rear quarter panel in an accident? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-02-2006, 01:52 AM   #1 (permalink)
2GR FTW
darksparkz's Avatar
View darksparkz's Photo Gallery
4th Generation Replacing rear quarter panel in an accident?
Got into a medium sized accident where the car hit the rear left of my Camry. Between the fuel door and rear tailight. A fairly big hit that doesn't look like it's dent-fixable. The hit is bigger then the size of my head, and deep enough for it to move the carpet and body molding from inside the trunk. How would I look for replacement parts for something like that. It looks like the whole part is connected to the roof of the car and to the other side. It's not like a fender where you'd replace one piece.
Also, after the hit, the Camry slid into a curb with the front right wheel hitting the curb. Now the steering wheel doesn't drive straight when the wheels are pointed forward. The wheel is about 30 degrees to the left now for me to be able to drive straight. Would an alignment fix this? Also, now it feels like that rear left strut rubs onto the wheel, I highly doubt that there's strut damage, but it rubs on bumps now.
I'll still take this to a body shop and see how this works out for an estimate, but for now, what's your estimate on fixing this?
I'll probably take pictures tomorrow morning if necessary.
2007 Toyota Camry SE 2GR-FE
Retrofit TSX HID Projectors | TRD Lowering Springs | Smoked LED Tails | Custom Apexi WS2 Catback Exhaust | BlueBatMobile Eyelids| UR Front Strut Bar | UR 23mm Rear Sway Bar | K&N Short Ram Intake| Kenwood DNX8120 In-dash | Lexus IS350 18" Wheels | Toyota Japan JDM Vent Visors | IS-F Black Leather Shift Knob
Other cars: F20C (AP1) | 2JZ-GE (JCE10)
darksparkz is offline   Reply With Quote
Old 09-02-2006, 02:37 PM   #2 (permalink)
Go camry goooooo
DrewsCam's Avatar
Gameroom cash: $184280
View DrewsCam's Photo Gallery
its gona be alot, an entire quarter panel cut off and then replaced and maybe some axle problems up front
11/19/2007 Gen 6 08 Camry SE.
Rockland Toyota / Scion Showdown 4.0 Sept 26th
DrewsCam is offline   Reply With Quote
Old 09-03-2006, 01:43 AM   #3 (permalink)
2GR FTW
darksparkz's Avatar
So they'll have to cut off the panel and weld it back on or something? I googled around and can't find a price on rear body panels for it.
Old 09-03-2006, 01:56 AM   #4 (permalink)
View southpawz's Photo Gallery
Yup...it is all one panel so it will have to be cut out and welded back in. I have a dent in my left rear quarter panel too...was like that when I got it so not gonna spend the $$ to fix it. Just hoping if I have an accident it is on that side
southpawz is offline   Reply With Quote
Old 09-03-2006, 12:32 PM   #5 (permalink)
Gameroom cash: $133100
View profuse007's Photo Gallery
this thread is worthless w/o a pic.
2009 Camry SE || Techstream V.6.0 with Openport 2.0 || TSX 4300K Denso
Houston-TX: need key chip, remote, or body features programming? PM me.
profuse007 is offline   Reply With Quote
Old 09-03-2006, 01:27 PM   #6 (permalink)
2GR FTW
darksparkz's Avatar
Any idea of how much this should cost? $500 or so?
Edit: How would I go about on fixing the problem with the steering? It seems like the steering wheel is just misaligned with the direction the wheels point. Maybe a simple 2 or 4 wheel alignment may fix this? Or would I need to bring this to a repair shop to check out the axles.
Old 09-03-2006, 02:03 PM   #7 (permalink)
replacing panel is not necessary, it would cost a lot of money.
w/ the crease thats on the panel, the body work would be about 750 at a local bodyshop, and will look good as new.
theres no axle for the back wheels. as for as the alignment, any shop can determine if the suspension is crooked or not. i was hit at teh same spot and the shock was bent.
Old 09-03-2006, 02:42 PM   #8 (permalink)
2GR FTW
darksparkz's Avatar
I mean the axle for the front wheel. After getting hit, the car slid into a curb with the front right wheel hitting it and scraping against it. That made the steering wheel be misaligned with the way the wheels are pointed. For example, when the wheels are pointed forward and the car is going in a forward direction, the steering wheel is turned 30 degrees to the left for the car to be able to drive straight.
I think the strurt might've been bent in the rear too, because excessive rubbing occurs on dips or bumps in the road, even in turning.
Old 09-03-2006, 02:58 PM   #9 (permalink)
i see what you mean. i remember mine cause an excessive steering misalignment.
Old 09-04-2006, 08:46 PM   #10 (permalink)
2GR FTW
darksparkz's Avatar
Bump for a little bit more input.
Old 09-04-2006, 10:04 PM   #11 (permalink)
Was the accident your fault or someone else's? ....If someone hit you I wouldnt worry about cost and let their insurance pay for it...unless you are trying to cut cost and make alittle on the deal
Old 09-04-2006, 11:27 PM   #12 (permalink)
2GR FTW
darksparkz's Avatar
Actually my friend was driving it. He rushed out of an alley and didn't yield right of way, the oncoming car hit the side of the camry. That's why the momentum pushed the front right wheel onto the curb. Barely any damage to the other person's car, it was a Plymouth mini-van that had a bit of bumper damage and fenders shifted a bit.
Old 09-05-2006, 12:13 AM   #13 (permalink)
View Kitto's Photo Gallery
replacing the panel should cost at least 2000...
Kitto is offline   Reply With Quote
Old 09-05-2006, 10:47 PM   #14 (permalink)
2GR FTW
darksparkz's Avatar
Just got an estimate from a well-known body shop. They said it would be $1,800. That's to guarantee me that they'll fix it. They'll first try to fix it without replacing, but if that still doesn't look good, they'll replace it as well. He said there is a chance of frame damage cause the insides look bent. The rear bumper will be replaced as well.
Whiteline; Superpro and Dobinson Group Sale raptorracing Supporting Vendor Sales 222 03-09-2007 06:51 AM
Hitting Rear Locker Button By Accident ! currentsupply 2nd Generation (2005+) 15 06-30-2006 03:37 PM
Replacing 94 LE Center Panel Green Dragon 3rd & 4th Generation (1992–1996 & 1997–2001) 26 01-20-2006 08:48 PM
CAMRY letter's on teh rear panel claymore Camry & Solara Lounge 8 10-15-2002 05:30 PM
ae86 rear quarter? lloyd Archived Corolla threads 17 08-12-2002 10:44 PM
