check engine light code p0125 p1135 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-02-2006, 02:08 PM   #1 (permalink)
View camry03's Photo Gallery
help.. it's a 98 camry v6 w/ 114k, originally had a check engine light p1133, p1135, then i replace the a/f sensor that's on the front engine(behind radiator, not firewall). then reset the lights and drive.. now i get the code p0125 and p1135.... did i change the wrong sensor?
which is bank 1 on the v6? is it the side behind the radiator, or the side infront of firewall??
tks for the help!
the car temp warms up fine, it's not overheating.. so the termostat should be bad.. right?
camry03 is offline   Reply With Quote
Old 09-03-2006, 12:44 AM   #2 (permalink)
95% Biker / 5% Driver
Digger1's Avatar
View Digger1's Photo Gallery
Lightbulb
tks for the help!
03,
The first thing I'd do is to recheck the wiring on the A/F sensor. You may have an open or a short there.
Digger1
"If you don't understand the technology you depend upon, you will someday be a victim of that technology."
Digger1 is offline   Reply With Quote
Traction Light with P0135 check engine code fincobbler Solara 8 05-01-2008 08:51 AM
looking to buy a 88 Supra(california Emissions) chi-toy Supra Forum 3 12-09-2007 09:09 AM
2jz-gtte Jmac279 Supra Forum 30 02-02-2007 01:54 AM
2005 Matrix Check Engine Light? : OBDII SCanner Buying Tips? Matreks 1st Generation (2003-2008) 13 07-06-2005 12:25 AM
