replacing '92 Camry driver door handle? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-02-2006, 04:07 PM   #1 (permalink)
Tab
View Tab's Photo Gallery
Hello:
Some time ago I visited here and I think this is where I found detailed (or a link to) instructions for replacing the outside driver's side door handle ('92 Camry). I can't find them now and need to. We never got around to trying to replace it back then (it's our "backup car"), but we want to now before winter gets here. I'd appreciate it if anyone could point me to them.
Thanks so much!
Tab
Tab is offline   Reply With Quote
Old 09-02-2006, 10:28 PM   #2 (permalink)
Dealer Tech..not Toyota
Axel Kain's Avatar
View Axel Kain's Photo Gallery
search? buy a haynes manual? take the door panel off, un bolt, and remove actuation levers, unplug door handle, and remove... install is reverse of removal.
Quote-Terrastrife: Axel the confusion specialist!
-1992 Camry V6 XLE- *3VZ-FE* (with a dead auto trans.) <SOLD!
Newest addition- 1987 300zx Turbo! what a blast!
Axel Kain is offline   Reply With Quote
Old 09-03-2006, 09:34 AM   #3 (permalink)
'93 LE Wagon, V6
View DFBonnett's Photo Gallery
Dowload the manual...
http://oregonstate.edu/~tongt/camry/index.html
DFBonnett is offline   Reply With Quote
Old 09-03-2006, 11:16 AM   #4 (permalink)
View Isaac-1's Photo Gallery
Be careful removing the interior latch trim ring, it tends to crack.
Ike
Isaac-1 is offline   Reply With Quote
Old 09-03-2006, 12:15 PM   #5 (permalink)
Gameroom cash: $133100
View profuse007's Photo Gallery
to remove the door panel
1. remove int handle trim. insert a flat at teh pivotal point of the lock and latch.
2. remove all hardwares holding the panel
3. pop off door panel from under.
to remove the ext handle
1. reach up and pop off two rod clips(latch and lock/unlk) from the ext handle. clips are very fragile
2. unbolt two 10mm holding the ext handle. youre done removing!!!
post your result some pics.
2009 Camry SE || Techstream V.6.0 with Openport 2.0 || TSX 4300K Denso
Houston-TX: need key chip, remote, or body features programming? PM me.
profuse007 is offline   Reply With Quote
Official 2007 Toyota Camry Announcement, Images & Specs EKam Toyota News 1481 05-17-2007 10:50 PM
Fusion marches past Camry! sciguy0504 Camry & Solara Lounge 38 05-04-2006 07:27 AM
2002 - 2005 Toyota Camry review! Lexusfreak 5th & 6th Generation (2002-2006 & 2007-2011) 2 03-27-2006 04:43 AM
92 Camry driver airbag ONLY Trueno 3rd & 4th Generation (1992–1996 & 1997–2001) 3 05-18-2004 01:40 AM
