Diagnosis Problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-02-2006, 04:19 PM   #1 (permalink)
View rezzinator1110's Photo Gallery
3rd Generation Diagnosis Problems
I'm trying to diagnose an engine code and I'm not familiar with the Camry. I shorted E1 and TE1 in the OBD connector and in counting the check engine light flashed I got up to 400 and gave up. Does anyone know what this means or if I did something wrong??
Your help would really be appreciated.
rezzinator1110 is offline   Reply With Quote
Old 09-03-2006, 09:14 PM   #2 (permalink)
5SFE
Lord_Anarchy's Avatar
View Lord_Anarchy's Photo Gallery
You aren't counting correctly.. Pay attention and you'll see that it's long duration blinks, then short duration. Eg. (long, long, long -short pause- short, short -long pause- repeat code) 1,2,3- 1,2 The problem code is "32". If you can record it, we'll gladly read it for you.
Yes, it keeps blinking but what it's blinking is the same code over and over again.
Lord_Anarchy is offline   Reply With Quote
Old 09-04-2006, 03:37 AM   #3 (permalink)
View marc780's Photo Gallery
res i bought a proper scanner, that works, at harbor freight for $30. I tested and used it at work for our 2000 Ford Ranger (POS) fuel truck with CEL on, and it said "0303" which meant cylinder 3 misfire. (I have a list of codes just ask). I changed the spark plug, the cheap scanner cleared the code, problem solved.
Known problems slcpunk General Lexus Discussion 3 12-16-2005 12:51 PM
Electrical Problems - Searched and found little help. Delay_FTB General Discussion 5 12-05-2005 04:43 PM
electrical problems arising... battlekat49 Camry & Solara Lounge 2 08-14-2005 02:40 AM
1999 Camry problems nonstop only 28,800mi neuspeed 3rd & 4th Generation (1992–1996 & 1997–2001) 3 05-04-2004 01:03 AM
