98 speaker issue - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-02-2006, 09:43 PM   #1 (permalink)
View lenjack's Photo Gallery
98 speaker issue
98 with blown passenger front door speaker. This is an aftermarket speaker. Need detailed info on removing door panel for speaker replacement. How to do it without making a mess or damaging water seals or trim.
lenjack is offline   Reply With Quote
Old 09-02-2006, 11:36 PM   #2 (permalink)
touringcamry's Avatar
Gameroom cash: $510625
Go to the Audio forum, click on "Ultimate Audio Sticky"
There are instruction in there on how to replace the speaker.
2007 Camry 2.4L 5M
Old 09-03-2006, 12:09 AM   #3 (permalink)
View imbest123's Photo Gallery
dont worry, its a lot easier than you think.
imbest123 is offline   Reply With Quote
Old 09-03-2006, 12:22 AM   #4 (permalink)
Thanks...very helpful. One problem. The photo showing the insertion of the screwdriver to remove the door handle trim does not show. There is a small red "x" in it's place. All other photos show properly. how can I access this photo?
Old 09-04-2006, 06:06 PM   #5 (permalink)
small bump
Old 09-04-2006, 06:21 PM   #6 (permalink)
You mean the trim around the inside lever to open the door?
2007 Camry 2.4L 5M
Old 09-04-2006, 09:11 PM   #7 (permalink)
I'm referencing this section...below is the paragraph preceding the non viewable photo and the red x:
The hardest part to remove is the door handle trim. For this you'll need a screwdriver and a special touch. Using the picture below as a reference, insert the screwdriver where indicated and leverage the screwdriver so you're lifting the trim away from the door handle. It's not intuitive, but if you leverage it just right the trim will pop off and out easy as cake.
98 Camry Rear Speaker Installation problem ! Help !!!!! 98Toyozip 3rd & 4th Generation (1992–1996 & 1997–2001) 4 08-07-2008 09:41 PM
1st issue with 07'Camry AESANTIAGO 5th & 6th Generation (2002-2006 & 2007-2011) 949 01-08-2008 03:49 PM
Getting my amp to turn off with my stock head unit Waterwookiee Audio, Video, and Security - Tech 10 03-22-2006 02:00 PM
'98 Camry tranny issue... jermag24 3rd & 4th Generation (1992–1996 & 1997–2001) 2 08-18-2005 12:20 PM
98 corolla front door speaker installation fatredcircle Archived Corolla threads 4 11-05-2002 10:07 PM
