I broke a valve cover
. Somehow I read the torque specs as 51 ft/lbs.
The dealer wanted like approx $230 but I got a junkyard spec for $35.
The back cover is the absolute bitch, plan an afternoon around this. Eat lunch early.
I recommend getting the metal gasket for the intake since you are there.
Do the plugs and change the plug cables if they are old.
I also did the distributor cap and rotor arm since I figured I was there.
If you are not leaking from the sparkplug tubes, don't change the gaskets out.
Unnecessary frustration.
