Low Idle problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-05-2006, 09:30 PM   #1 (permalink)
mox
God Machine
mox's Avatar
View mox's Photo Gallery
Low Idle problem
My '93 Auto seems to be hacing some problems
First the idle is really low, car is shaking.. it's like 500rpm
And when I give it some gas when the car comes back to idle the engine dies
I haven't moved the car for the last 2 months and I installed a new battery in it today (replaced my toyota battery for an optima)
Anyone have an idea what it can be?
'92 Camry SE V6 5 Speeds (Pics: 1 | 2 | mox.monchar.com) ('06-now)
Previously owned: '99 Corolla,MT ('99-'01), '97 Camry XLE V6,AT ('01-'02), '92 Camry SE V6,MT ('02-'04), '99 Solara SE V6,MT ('04-'06), '93 Camry LE V6,AT ('06-'07)
mox is offline   Reply With Quote
Old 09-05-2006, 09:50 PM   #2 (permalink)
nuchieboy's Avatar
Gameroom cash: $203299
View nuchieboy's Photo Gallery
i would try bringing the idle up a little bit to just under a 1,000 rpm....try adjusting the idle and then see what happens....also make sure all ur plugs and secure in their slot...spark plugs anyways....u have to make sure they are all firing in order....but try those 2 things
2009 Camry SE V6 loaded
Mods: Borla Dual Exhaust with no resonator, K&N Intake, 5k HID headlights and 5k HID foglights, LED Tail lights, Complete interior leds, Ultra Racing Front Strut Bar, Ultra Racing 19mm rear sway bar, 20% tint, Rosen navigation system, 19 inch ASA GT1 wheels
nuchieboy is offline   Reply With Quote
Old 09-05-2006, 09:51 PM   #3 (permalink)
mox
God Machine
mox's Avatar
How do you adjust the idle?
Old 09-05-2006, 11:19 PM   #4 (permalink)
View marc780's Photo Gallery
I'd look at the following items:
1. When was the last time fuel filter was changed? If you dont know, change it.
2. Clean throttle body and IAC. Do a search and there are 100 posts on this, some by me. It's easy to do.
3. Check alt output, use a Volt ohmmeter, they can be had for ten bucks at walmart. another easy thing to do even if you have never seen one of these devices in your life. Idle engine for several minutes, put probes to battery - 14.0 to 15 volts is what you want to see. Any less the alt could be causing the problem.
(On one occasion, my engine kept dying, losing power and doing the same things you describe. Ultimately I found out it was the alternator, and yet the dashboard light never even flickered! )
4. If none of these works, check fuel pump output...the pressure could be low and maybe it needs to be replaced.
Old 09-06-2006, 01:43 AM   #5 (permalink)
mox
God Machine
mox's Avatar
Thanks !
Yeah I got a multimeter
I'll try that asap
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 0 03-29-2006 11:01 AM
IdLE PROBLEM ZIXXER 1st Generation (1995.5–2004) 2 12-07-2005 06:47 AM
98 4 cy. - low idle on start corrinebean 3rd & 4th Generation (1992–1996 & 1997–2001) 6 12-02-2004 07:06 PM
high idle problem 93twinstick General Discussion 4 11-04-2004 12:50 PM
