Camry V6 1997 Power Steering Pressure Hose - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-06-2006, 10:56 PM   #1 (permalink)
View shamjamal's Photo Gallery
Canada Camry V6 1997 Power Steering Pressure Hose
A dealer advised me that I need to replace Power Steering Pressure Hose which is leaking. I have a Camry XLE V6 and has only done 105,000 klm. Did any one have this kind of problem? The dealer also suggested that I replace a cylinder head gasket which is also leaking. The pressure hose cost # 800.00 including labor. The part cost is $ 575.00. Can I trust the dealer or should I do some thing else first? Please advise.
shamjamal is offline   Reply With Quote
Old 09-06-2006, 10:59 PM   #2 (permalink)
Canada Timing Belt Camry XLE V6
My camry has done 105,000 Klm. Is it time now to replace timing belt?
Old 09-06-2006, 11:30 PM   #3 (permalink)
MOUTH SLAP!
Your Uncle Moe's Avatar
View Your Uncle Moe's Photo Gallery
When was the last time the timing belt was changed? If it was never changed, I would think its about time It was changed. How bad is the head gasket leaking? Are you using synthetic oil? Sometimes it leaks through giving the impression that the head gasket is busted.
96 Camry V6 LE & 90 Eagle Talon TSI (AWD TURBO)
"Love is all you need to know and all you need to know is love is all you need to know."
Your Uncle Moe is offline   Reply With Quote
Old 09-07-2006, 12:18 AM   #4 (permalink)
this is what i say >
v-cam's Avatar
View v-cam's Photo Gallery
mate its seems strange that you have a busted head gasket at only 100,000 km. Same with the power steering hose. and thats insane money for a hose.
Take it to a different mechanic and grab a 2nd opinion.
True car enthusiasts are open-minded to everyone's creation
v-cam is offline   Reply With Quote
Old 09-08-2006, 12:52 PM   #5 (permalink)
Canada
The oil is not dripping from the valve cover gasket. (I made a mistake, the oil actually leaks from valve cover and not cylinder head) since I do not see any marks on the floor where I park my car. So it seems there may be slight leak. I am changing the timing belt for the first time on Monday. Will forget for now the issue of power steering pressure hose as it does not seem serious at all at this time as advised by a private garage. With the timing belt, I have been advised by a private garage to change the kit as well which consinsts of some bearings etc. I am also replacing the water pump and the spark plugs at the same time. My car again is 1997 Camry V6 which has done only 105,000 Klm.
Old 09-08-2006, 12:58 PM   #6 (permalink)
My mistake. The leak is from the valve cover gasket and not cylinder head gasket. It is leaking slightly. I am going to have it replaced at the same time I am having timing belt replaced together with its kit and spark plugs as well. A private garage told me that there is no need to change the power steering pressure hose. It shows that there is slight leak. Nothing is dripping on to the floor where I park my car. The mechanic also advise that if and when there is a need to replace, what he does is that he sends the hose to some specialist who takes off all the hardware from the old hose and refits them perfectly to a new hose only. This process saves a lot of money.
Old 09-24-2007, 10:24 AM   #7 (permalink)
Toyota Fan
View Todd Soden's Photo Gallery
I just had the pressue hose replaced on my 2000 4 cyl. I took it to the deal to get it diagnosed first, but had a local mechanic do the work. Unfortunately the part was still $400 as no after market part was available. So the job with labour came out to be about $600.
I was advised that it should be done or I was risking losing the powersterring pump ...which apparently could be costly (even more than the hose) to replace.
2000 Camry CE
2000 Echo
Todd Soden is offline   Reply With Quote
Old 09-24-2007, 12:22 PM   #8 (permalink)
R.I.P. '95 Camry LE V6
Black95Cam's Avatar
View Black95Cam's Photo Gallery
my return hose was leaking and my valve cover gasket was leaking only at 89xxx. but at the end it all depend on if the owner or previous owner keep up the maintenances.
Originally Posted by Tony the Tiger View Post
The Camry is a car that I can rip out someone's pride, stab it, beat it, and completely bash their egos, and it's so ridiculous that the person comes back with a hysterical laugh... ROFL They got trainlengthed by a Camry that in their mind, was a 18 sec car.
R.I.P. Black95Camry..
Black95Cam is offline   Reply With Quote
History of the Toyota Camry Ratko Camry & Solara Lounge 54 01-13-2012 08:42 PM
Official 2007 Toyota Camry Announcement, Images & Specs EKam Toyota News 1481 05-17-2007 09:50 PM
2006 RAV4 Features & Pricing [Canadian Spec] rolla-XRS Toyota News 19 01-03-2006 11:37 AM
GEN II V6...power steering pressure hoses...easy fix? ArmyofOne Camry & Solara Lounge 4 02-07-2005 11:05 AM
