first of all, are you using the correct remote? RS3000 for your year should be using a black, 2 button, football shaped remote. Does your remote match that?
secondly, have you located the ecu unit of the alarm. If you have, what color is the ecu unit?
my third and final question is, what procedure did you use?
My instinct tells me that your alarm is NOT rigged. Neither is it not working properly. The reason for the blue and red wire being tapped MIGHT be that the previous owner needs to powerup/activate something with the auxilary button on your remote. I am not absolutely sure on this though. if you can show us a picture of the "suspicious" wiring, someone might be able to help you.
answering all my questions above, will provide useful info for all TN members to help you.
