Just changed the timing belt: Wow! What a differece! - Toyota Nation Forum : Toyota Car and Truck Forums
post #1 of 26 Old 09-07-2006, 09:37 PM Thread Starter
'00 Camry V6 (1MZ-FE)
Quoted: 0 Post(s)
(Thread Starter)
Thumbs up Just changed the timing belt: Wow! What a differece!
I just have all the belts and water pump changed at the dealer, wow! what a difference. I've been having this V6 camry for 3 months, and I have never truly experienced the V6 power until now. I've always thought that the auto tranny must be the reason slowing the car down.
Now, I only need a little throttle, then the car will go.
So, tight belt == better performance? Or maybe the belt was loose before it was changed?
NewRacer is offline
post #2 of 26 Old 09-07-2006, 09:47 PM
Quoted: 0 Post(s)
Is this also true for the 4 cylinder?
1994 Camry LE I4 Leather, sunroof, Alpine CDA-9856 head unit, Alpine Type S Speakers, Alpine 450W amp, and 2 12" Alpine Type E Subs
2007 Camry XLE V6 Magnetic Grey/Bisque, Navigation, Smart Key, and 20% tint
David1990 is offline
post #3 of 26 Old 09-07-2006, 10:24 PM
Quoted: 0 Post(s)
I don't think changing a belt will make any performance difference... correct me if I am wrong...
Kitto is offline
post #4 of 26 Old 09-07-2006, 10:30 PM
Quasi-Evil Monkey
renmike's Avatar
Quoted: 0 Post(s)
iTrader Score: 14 reviews
All that was changed was the water pump and belt?
Perhaps the belt has been changed in the past, and whoever did it had the timing off just a little bit, I dunno.
Current Ride(s): 08 Pontiac G8, 02 Mitsubishi Lancer, 94 GMC Sierra
Former Ride(s): 93 Camry SE V6 5-Speed , 95 Camry DX 4-cyl
renmike is offline
post #5 of 26 Old 09-07-2006, 10:34 PM
Ninja-rator
RningOnFumes's Avatar
Quoted: 4 Post(s)
I'm thinking it didn't give more performance, NewRacer regained what he should have had from having a worn belt.
RningOnFumes is offline
post #6 of 26 Old 09-07-2006, 10:42 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I had a tune up (timing and spark plugs) last month, but didn't feel a difference.
Possibly.
NewRacer is offline
post #7 of 26 Old 09-07-2006, 10:43 PM
this is what i say >
v-cam's Avatar
Quoted: 0 Post(s)
timing was out on old belt is my guess.
True car enthusiasts are open-minded to everyone's creation
v-cam is offline
post #8 of 26 Old 09-07-2006, 11:56 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
No, I did a tune up last month.
So it must be the old belt was worn. I only had 78k miles, Toyota suggested timing belt change every 90k, but apparently it's already worn before 90k.
NewRacer is offline
post #9 of 26 Old 09-08-2006, 12:08 AM
v-cam's Avatar
Quoted: 0 Post(s)
If it was your belt causing your lack of power, it means it was probably stretched causing the timing to be out no matter how much you tune it.
so yeah, timing was out.
No belt will ever add kw, you have just got it back in tune. thats it. welcome back to stock power!
v-cam is offline
post #10 of 26 Old 09-08-2006, 01:24 AM
VeeZed
JetspeedCamry's Avatar
Quoted: 0 Post(s)
Possibly.
No, not possibly...DEFINETLY.
I somehow doubt this, changing a belt will not give you performance, UNLESS it was incorrectly timed in the first place. And if it was a cam gear that was out, the engine would not have run very well at all..rough...idling problems etc.
The only way it could have occured if thats all that was changed is, the person wouldve retimed the engine after the job...and perhaps set it to the CORRECT ignition advance..maybe it was running retarded that whole time.
Stretched belt, tight belt ETC..= Bullshit.
The V6's have AUTO tensioners that take up the slack and PREVENT the belt from loosing its tension or gaining it for that matter.
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline
post #11 of 26 Old 09-08-2006, 01:34 AM
v-cam's Avatar
Quoted: 0 Post(s)
you would have to be nuts to retard the engine, all timing info is under the bonnet, the mechanic must have been blind. bad mechanic!
mate, did you fill up with higher octane fuel after the belt was replaced, maybe they replaced your air filter aswell, your old one clogged? or cleaned your intake? maybe its all in your head? could be a million things.
v-cam is offline
post #12 of 26 Old 09-08-2006, 02:00 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
No, only belts (all the belts), and water pump have been changed. I use premier gas all the time, and the air filter is K&N, which is less than 3 months old. Timing was adjected last month at the tune up. So, my old belt must have been worn.
I don't know why, but the difference is vast! I used to turn the overdrive off when going home (uphill), now I don't need to. kind of weird......but I love how it drives now!
NewRacer is offline
post #13 of 26 Old 09-08-2006, 09:03 AM
mixed bag 'o vehicles
ghettosled's Avatar
Quoted: 6 Post(s)
im with the majority of people here, a new timing belt should not have any effect on power. maybe they also cleaned your throttlebody as a simple and kind gesture while it was in the shop?
ghettosled is offline
post #14 of 26 Old 09-08-2006, 09:40 AM
Quoted: 0 Post(s)
Man, at least someone in this discussion has some sense. An old timing belt will not effect performance, no ifs, ands, or buts. It just doesn't, and anyone that still believes otherwise shouldn't be giving advice on car repair. If the timing was off by 1 tooth, then you would really know it, as it would run like garbage.
I think some of you are confused between cam timing and ignition timing. Doing a 'tune up' will not affect cam timing. I dont know if the OPs car has a distributor or not, but if it does, you can change the ignition timing with that.
Chances are that either the ignition timing was fixed at the distributor end, or this is merely a result of having the battery disconnected and the adaptive fuel maps were reset. Either that, or its all in your head.
BTW, this comes from someone who has changed multiple timing belts and chains.
01 BMW 330Ci - 5spd / 93 BMW 525i 5spd-SOLD/ 98 Camry LE
hooRAH is offline
post #15 of 26 Old 09-08-2006, 09:13 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
When I first got the car 3 months ago, it just didn't feel that powerful. My friend has a 95 Honda Accord V6 and his car felt a lot powerful than mine did. So I did a tune up (both timing and spark plugs), I changed the air filter, fuel filter, oil, and cleaned the throttle body. Also, I use premier gas only. Didn't make a hugh difference though.
After the timing belt change yesterday, my car just feels a lot more powerful than his 95 Accord V6 as it should, and it's definitely not in my head. So, something must be wrong before the timing belt change. Now the car just feels right.
Could it be a worn belt that was affecting the performance? Or could it be the water pump?
NewRacer is offline
User Tag List
Linear Mode Linear Mode
« Back
