98 Camry Rear Speaker Installation problem ! Help !!!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-28-2001, 10:58 PM   #1 (permalink)
View 98Toyozip's Photo Gallery
hi guys,
I bought 6x9" Pioneer speaker's for my
98 Camry.
I am not able to Install them!!.
The main problem is how to open up the rear panel ?(1st step)
Can you help by any means that how can I open up the rear panel .
(Any Pics for the Install)
I cant spend $50 for Installation so I need your help guys!
Thanks again.
98Toyozip is offline   Reply With Quote
Old 12-31-2001, 08:00 AM   #2 (permalink)
View speedemn's Photo Gallery
I believe the Haynes manual can help you a little bit on this matter. Look up how to take out your rear struts and it should give you directions on how to take apart the rear panel. I have a 1993 so the directions might not be the same so I can't be more specific than that, sorry. Haynes = $10 = very worthwhile investment.
On 2001-12-28 23:58, 98Toyozip wrote:
hi guys,
98 Camry.
Thanks again.
2003 BMW 540i 6-spd
2008 Toyota Rav4 Limited V6
2005 Mazda 3 Sport GT 5-spd (just sold)
1995 Nissan Maxima SE 5-spd... Best ET: 13.8... Best trap: 99mph (Gone)
1993 Toyota Camry LE (Gone)
speedemn is offline   Reply With Quote
Old 08-07-2008, 06:46 PM   #3 (permalink)
View psyanyde's Photo Gallery
i'm having the same probs
i got speakers for the back and the ones by the door
NO idea how to take that back apart
wish someone would write a DYI
1993 Camry V6 LE 4 Dr - 236K as of Feb 2008. All Stock.
psyanyde is offline   Reply With Quote
Old 08-07-2008, 08:30 PM   #4 (permalink)
It's pronounced "Nesquik"
View N35QU!K's Photo Gallery
You, I can help.
http://tw.youtube.com/watch?v=TTSAongCAQM
But if the Gen4 rear seats are anything like the Gen3, then you'll find this video helpful too, 98toyozip, otherwise, sorry...
Click image for vehicle info (UPDATED 12.01.09)
N35QU!K is offline   Reply With Quote
Old 08-07-2008, 08:41 PM   #5 (permalink)
View Albuynp Ryeno's Photo Gallery
DIY - rear seats removal & speakers
The only real diff between the gen 4 n gen 3 is the location of the things to pull down the rear seat. Also the gen 3 has those 2 screws in the middle of that back cover hidden under 2 stoppers.
Also ur big problem isnt going to be removing the old speakers or getting to them. But putting in the new speakers.
Your going to have to make an adapter with a medium density partical board. DONT bother drilling new holes, i tried it, ended up terrible. They wont screw even tights enough and will cause noise from the speaker when it vibrates since its not on tight enough.
i like 6.25 speakers more since perfect circle is better quality and its easier to make an adapter for.
Also ur other problem is gonna be keeping the speakers from hitting on the cover. You have to make sure the aligment is perfect or else the speaker will hit the top cover when it moves upward, causing unwanted noise. U have a lot more room for error with 6.25 speakers over 6x9 speakers for this.
Also if you want u can sand or dremel down the actual cover. Once you take it off, you can see the hole in it isnt nearly as big as the speak grill. If you expand that hole it will fix the problem of the speaker hitting the cover (if ur aligment wasnt perfect to start with)
1995 Camry V6 LE - Sold
1998 Camry LE
1992 SC300 5SPD
1992 SC400
Albuynp Ryeno is offline   Reply With Quote
Overall Comparison: Toyota Camry XLE V6 v.s. Pontiac Grand P CamryLeb Camry & Solara Lounge 25 08-13-2007 10:55 PM
98 Camry Rear Suspension Noise, Help. 98-XLE-V6 3rd & 4th Generation (1992–1996 & 1997–2001) 0 07-09-2002 09:08 AM
'98 camry handling/tracking problems wiscokid 3rd & 4th Generation (1992–1996 & 1997–2001) 2 05-14-2002 01:27 AM
96 Camry LE V6 vs 98 Camry XLE V6 2001CamryLE 3rd & 4th Generation (1992–1996 & 1997–2001) 7 05-13-2002 07:53 PM
