Originally Posted by Ken4
I had to read it twice to understand! Anyway I dont think it will work, there is just not enuf space to do what you're doing. If you have more or less positioned the piston groves and aligned the top seat properly and manage to get the lock nut on, it will most likely be sitting in the groves properly. To tighten to specs, simply mount the strut back on the vehicle and tighten there.
OK maybe I was a little wordy. Simply put the spring wont compress far enough down with the new upper spring cushion on to install the strut mount to the rod properly. I am bring it to a shop that can compress it way down so I can intall the mount aligned with the rod and tighten the nut. When I put the nut on now it just spins the strut piston as I turn it. THe upper mount MUST be LOCKED into place on the rod so the rod does not spin. It's been a nightmare job. All went well until I had to reassemble the new strut-it was very very frustrating. Once these cars hit 180,000 you can spend everyweekend doing maintenance if you want to and still not fix everything. After these struts are done I am selling the car. Time to go when your hobby is working on cars but your daily driver always needs something replaced, that's when your hobby becomes work. I love those toyota commercials where they show people showing that they have 250,000 miles or 300,000 miles, what they dont show is that they are on their back in the driveway everyweekend fixing stuff.
Don't get me wrong the car has saved me TONS of money over the past 5 years but even after I am done with the struts, there is still an exaust leak. an oil leak, a water leak from the windshield, the rear rotors are not looking too hot, rear sway bar bushings etc etc etc. The camy has been great but it's mileage is really catching up to it, I am going to stat looking for a new car this month.
