running rough 4 cyl - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-18-2006, 05:56 AM   #1 (permalink)
View 68Malibu's Photo Gallery
running rough 4 cyl
I looked at a 99 to buy the other day and the engine started right up and idled real smooth. Let it run about 3-4 min then went for a test drive. Car is a 5 spd and as soon as I began to let out the clutch the engine began to studder and the car hesitated until I got up to about 2,500 RPM. Did the same in all gears.
When I parked the car, I left it running and popped the hood. Engine was idleing low and running rough - visibly shaking.
The check engine light is on but I don't know why. Do you think this could be the EGR? I will try to scan for codes before I buy the car but don't want to buy a scanner so I may see if Auto Zone will loan one to me.
68Malibu is offline   Reply With Quote
Old 09-18-2006, 07:28 AM   #2 (permalink)
View heller's Photo Gallery
I would also check out the MAP sensor, that could also cause the engine to idle rough, only problem with the MAP is they are quite expensive around $300
'96 Camry I-4 (4 engines later)
-Pioneer head unit, 10" rockford fosgate(old punch style), 400 watt Clarion Pro Audio Amp, 6x9" Alpine Type-S
'97 XLE Camry V6(Stock)
'98 Chevy Cavalier R.I.P.
'02 Trans Am WS6 LS1 (600 H.P)
heller is offline   Reply With Quote
Old 09-18-2006, 05:42 PM   #3 (permalink)
View marc780's Photo Gallery
68Malibu if you are talking about a car you might buy, id just keep looking, unless its in particularly fine shape or a great price. The idle problem could be anything from a dirty IAC to low compression, who knows, not me not you...but this sounds like a big red flag to me anyway and why bother with it when there are so many used Camrys out there.
Old 09-18-2006, 07:16 PM   #4 (permalink)
Thanks. It was / is an intermintent problem so I knew it was not mechanical. I checked the codes and it came up with multi-cylinder misfire and cylinder #3 miss. Anyway, the wires are original and I pulled them out ot the head and #3 was arching through the black tube.
I went ahead and bought it. One owner CE, 5 spd (what I wanted), a/c, pw, pdl - decent shape and appears to be well maintained. Only 78K miles and I paid $4K.
I'll repost afte rthe tune.
Old 09-20-2006, 05:56 PM   #5 (permalink)
I just changed the plugs and that did the trick. Runs great now. #3 wire was arching within the tube and the plug had some issues. Ordered NGK wires so will try those too.
Old 09-20-2006, 06:18 PM   #6 (permalink)
felonyr301's Avatar
View felonyr301's Photo Gallery
$4000 for a 99 ce 5speed with 78k miles on it damn good price well compare to what i seen when i was seraching for my first car which i got a 95 le with the moonroof option in good shape.
felonyr301 is offline   Reply With Quote
Old 09-21-2006, 04:45 PM   #7 (permalink)
Gameroom cash: $303055
The new wires sound like a good idea. With new plugs, the wires have an easy time firing the new and clean plugs. After they get a few thousand miles on them you might have the plug wire problem in #3 return.
Mike
1st issue with 07'Camry AESANTIAGO 5th & 6th Generation (2002-2006 & 2007-2011) 949 01-08-2008 02:49 PM
91..running rough Bobbie 4Runner Lounge 3 11-05-2005 01:32 AM
91 tercel running rough Help girlietercel Tercel, Paseo, Starlet, and Sera Forum 3 12-14-2003 01:07 AM
95 Camry running rough at all speeds ralph855 3rd & 4th Generation (1992–1996 & 1997–2001) 2 12-12-2003 09:35 PM
