oil consumption - install TRD supercharger? OPINIONS PLEASE!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-18-2006, 12:05 PM   #1 (permalink)
97trdcamry's Avatar
View 97trdcamry's Photo Gallery
4th Generation oil consumption - install TRD supercharger? OPINIONS PLEASE!!
I have a 1999 Toyota Camry LE V6 5spd. About every 3000 miles I have to put a quart of oil in. I know it's not leaking oil, and I don't see smoke coming from the exhaust. I'm sure it is using it somewhere. I am currently using Mobil1 5w30. I was considering going to 10w30 to help with the consumption problem. Maybe adding Lucas oil stabilizer as well. I plan on supercharging the car at 5.5 PSI. Proper fuel system upgrades will be installed. If I installed the supercharger, would the oil consumption get worse? I think it is likely. Maybe I should just rebuild the motor and do a full engine and supercharger install. I'm looking for opinions here. Thanks.
97trdcamry is offline   Reply With Quote
Old 09-18-2006, 12:12 PM   #2 (permalink)
View 91MR2quickNA's Photo Gallery
Rebuild the engine before supercharging. The engine won't use more oil, but it definitely won't use less.
That would be a good time to buy the Engine Overhaul Gasket kit from Toyota as well. Have your block and head resurfaced, and do a 3 angle valve job. You'll probably need to have your cylinders honed, and new piston rings put in.
I'm thinking of the TRD S/C as an upgrade for my V6 MR2 sometime soon, like maybe after I fully break in my engine.
Jason
2005 Tacoma D-Cab 4x4 Off-Road
1991 MR2 w/ ported 1MZFE (MZW20)
1991 MR2 N/A (SW21)
91MR2quickNA is offline   Reply With Quote
Old 09-18-2006, 12:32 PM   #3 (permalink)
97trdcamry's Avatar
I don't really want to invest the money in having the engine rebuilt right now. I was hoping to get about 8-10 months out of it with the supercharger on it. then I could build an engine right with forged internals and at a lower compression ( say 9.0-1 ). The engine only has 93000 miles on the engine. Is this plausable?
Old 09-18-2006, 12:51 PM   #4 (permalink)
SE V6 5spd aficionado
mazdaverx7's Avatar
Gameroom cash: $142520
View mazdaverx7's Photo Gallery
it is possible that your engine is very slowly using the engine oil. one quart per 3K is acceptable. you can supercharge the engine in its current state and it probably would last for a bit. a rebuild with stronger internals is the way to do it properly. make sure you get the correct fuel mods. dont want to run too lean and smoke the engine prematurly.
92 Camry SE 3VZ-FE 5spd 131K 6m1
85 Porsche 944 119K 5spd
88 RX-7 10AE 96K 5spd
85 RX-7 GS 5spd
05 RX-8 38K 6spd, 63 Ford Falcon 99K I6 3spd
mazdaverx7 is offline   Reply With Quote
Old 09-18-2006, 01:56 PM   #5 (permalink)
Gameroom cash: $303055
I agree completely. The current engine should last a while. However, your oil consumption will go up a bit, if only for the fact that you will be putting your foot in it a bit more after supercharging it. Increased RPM's mean increased oil consumption, IMHO. I would just check the oil a bit more frequently, say every 500 miles or so.
Incidently, you would have to be burning a considerable amount of oil to see blue smoke coming out the tail pipe in everyday driving; a lot more than 1 quart every 1000 miles.
Mike
Old 09-18-2006, 04:07 PM   #6 (permalink)
02
JMSinMD's Avatar
View JMSinMD's Photo Gallery
Question
I myself am supercharged and it seems like I average 1 qt loss every 10k. Is it necessary to replace the missing quart or can the V6 run off 4 qts without causing damage??
JMSinMD is offline   Reply With Quote
Old 09-18-2006, 05:09 PM   #7 (permalink)
97trdcamry's Avatar
4th Generation
Hopefully you don't go 10K or more before you change your oil. I go 5-6K and use Mobil1 extended performance. I believe that with the DOHC engine, running at 4 quarts instead of 5 would possibly starve the cams from proper oiling. I try to keep my oil topped off, check it every other time I fill up ( about 750 miles ).
Old 09-19-2006, 02:08 PM   #8 (permalink)
Yes, top it off. Oil has 3 functions in an engine; it lubricates, it cools and it seals. 4 quarts can't so the job as well as 5. With 4 you are down 20% of your oil. I like to top off cars when they go down about 1/2 quart. IMHO.
Mike
Old 08-03-2008, 09:58 AM   #9 (permalink)
View stshannon's Photo Gallery
the 1mz-fe motor is known for oil consumption. best thing to do is pull bank 2 valve cover and see if sludge is present. if not you could probably just replaced the valve stem seals and the problem should be fixed. usually is very rare that a re-ring is needed
stshannon is offline   Reply With Quote
Old 08-03-2008, 11:45 AM   #10 (permalink)
rty
Gameroom cash: $298766
View rty's Photo Gallery
I thought it was known for engine sludge?
A quart for 3k miles isn't bad. I would try 10w30 though.
rty is offline   Reply With Quote
Old 08-03-2008, 05:32 PM   #11 (permalink)
Gameroom cash: $924000
iTrader Score: 13 reviews
View ASG14's Photo Gallery
Ok, so am I the only one not loosing oil? My old Camry (5SFE I4) had leaks from every seal and lost 1q every 3k miles.
I have 120k miles, with a TRD SC, and use M1 5W30, and loose NO oil, and I run the piss out of my car. I did about 10 60-90mph runs over the last 2 days testing things. If your loosing that much oil, do not put on the SC, cause your likely going to blow something before long, espetially at 5.5PSI.
5 Lug Corolla WHAT?
Old 08-03-2008, 09:08 PM   #12 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
thread revival...
i burn no oil either
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
5s-fe turbo install list R94CamryT Hardcore Tech and Competition 32 04-29-2009 01:37 AM
Men, Women and Oil Changes... BLUEMEANIE Off Topic 15 09-26-2007 09:42 AM
F/S 2000 5spd turbo 5sfe solara trdcamrygracia Vehicles 15 09-14-2006 03:26 AM
TRD supercharger leaking oil?!? HELP!! 97trdcamry 3rd & 4th Generation (1992–1996 & 1997–2001) 1 08-19-2006 10:23 AM
