camry v-6 running bad - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-22-2006, 12:38 AM   #1 (permalink)
View Uluacam's Photo Gallery
I own a 1992 V-6 Camry 3VZ-FE.Ive changed the spark plugs,cap and rotor.The wires is coming in from spark plugs.com and it is the NGK type.It starts fine and once it gets to normal temperature the motor starts to idle down and when applying throttle it gets worse.It has no power to go.The timing is okay and I changed the oil and filter.On the road the car wont move like normally.What do I need to change or check?
92 Camry V6LE
Uluacam is offline   Reply With Quote
Old 09-22-2006, 01:06 AM   #2 (permalink)
View 94CoupeV6's Photo Gallery
Try pulling your negative battery terminal off before you go to bed one night and in the morning recconect it. My 1MZ-FE used to lose around 50% power randomly after 4,000 rpm's, then I tried pulling the negative terminal off for a while and put it back on and it ran perfectly normal. Also, at warmer temperatures, the car is supposed to idle lower, around 800 rpm's. If it's lower than that...then you probably have some issues.
94CoupeV6 is offline   Reply With Quote
Old 09-25-2006, 01:19 AM   #3 (permalink)
3rd Generation
I fixed the problem by replacing the wires with some nice NGK hyper silicone Power cables.I do run a cold air intake,so I replaced the Air filter with a new one.The car still ran rough so I figured it out and talk to some of my friends about it and found out that my Cataylic Converter was clogged so I punched it out and put it back on and now the car runs really fine.
92 Camry V6LE
Old 09-26-2006, 02:22 PM   #4 (permalink)
View marc780's Photo Gallery
try cleaning the throttle body if the issues come back, dirty TBI and IAC makes the symptoms you describe.
Fusion marches past Camry! sciguy0504 Camry & Solara Lounge 38 05-04-2006 06:27 AM
2002 - 2005 Toyota Camry review! Lexusfreak 5th & 6th Generation (2002-2006 & 2007-2011) 2 03-27-2006 03:43 AM
why do they show the camry in a bad way so much? lucanhookup Off Topic 19 04-21-2005 05:30 PM
Update on my 89 camry wagon. Still not running right. ScottaWhite 1st & 2nd Generation (1983–1986 & 1987-1991) 1 07-26-2004 04:31 PM
