double ground spark plugs necessary??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-22-2006, 08:27 PM   #1 (permalink)
View 68Malibu's Photo Gallery
I installed some replacement bosch single ground plugs that Auto Clone (zone) sold me only to skim my owners man to find the "only use double ground..." statement.
Is this really an issue?
Thanks
68Malibu is offline   Reply With Quote
Old 09-22-2006, 09:22 PM   #2 (permalink)
touringcamry's Avatar
Gameroom cash: $510425
For Toyotas, people generally recommend NGK or Denso plugs.
Double ground plugs are not absolutely neccessary, but they last longer. Gen 4 Camry 4 cylinder engine uses a waste spark ignition system which means that the spark plug fires twice during each 4 stroke cycle. It fires once from the center to the ground, and once from the ground to the center. Because the electrodes will erode twice as fast, they put twice as many electrodes to make the plugs last as long as plugs in an ignition system that does not use waste spark. For this reason, the recommended spark plugs are double platinum (platinum on the center and the ground).
2007 Camry 2.4L 5M
Old 09-23-2006, 03:55 AM   #3 (permalink)
View James100's Photo Gallery
I just bought the Denso plugs from the toyota dealer and they were $8.95 each
'98 Camry 2.2 106K (This is a friend of mines car)
James100 is offline   Reply With Quote
Old 09-23-2006, 07:15 AM   #4 (permalink)
Ouch on that price! I will stick with my $1.15 bosch plugs for now and change them later on.
Thanks touringcamry for the explanation.
Old 09-24-2006, 08:19 PM   #5 (permalink)
68: What type of Bosch plugs cost $1.15 each? Did you use copper plugs? If they're copper you'll need to change those out more often which will probably end up being the same cost as the Denso double platinums.
The Denso plugs can be had at Autozone for $6 ea. For about $11, you can get Denso Iridium which are supposed to deliver more power, but not last as long.
Denso's part number, IIRC, is PK20TR11 for the Gen 4 2.2l I4 spark plugs.
2007 Camry 2.4L 5M
Old 09-25-2006, 09:10 PM   #6 (permalink)
Sorry but I tossed the boxes and receipt so I do not know the PN. I know they said platinum and were bosch.
Old 09-25-2006, 09:20 PM   #7 (permalink)
nuchieboy's Avatar
Gameroom cash: $161949
View nuchieboy's Photo Gallery
4th Generation
i got the bosch platinum 4's and i ended up paying like 5$ a plug
2009 Camry SE V6 loaded
Mods: Borla Dual Exhaust with no resonator, K&N Intake, 5k HID headlights and 5k HID foglights, LED Tail lights, Complete interior leds, Ultra Racing Front Strut Bar, Ultra Racing 19mm rear sway bar, 20% tint, Rosen navigation system, 19 inch ASA GT1 wheels
nuchieboy is offline   Reply With Quote
Old 09-25-2006, 09:32 PM   #8 (permalink)
Darkside Cut Me!!!
Gameroom cash: $127223
View Hajoca's Photo Gallery
I am using NGK V grooves, copper plugs, BRK6EY11 that were selling for $4 CDN a pair, so I scooped several sets. The only place to get Denso/ NGK double grounded plugs here are Ebay sellers... which have screwed me before, and the Dealer which cost about 12.50 CDN Each.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Spark Plugs: Iridium vs. others Zach Ayres Supra Forum 11 12-18-2006 12:37 PM
How long do platinum spark plugs last? NewRacer Camry & Solara Lounge 8 05-24-2006 07:52 PM
Finally Changed My Spark Plugs....in 4 Hours... Eye8Pussies Camry & Solara Lounge 51 01-26-2006 02:19 PM
Anyone using Nology Silverstone Spark Plugs TRD_Rob Camry & Solara Lounge 1 03-18-2004 01:28 PM
Performance Spark Plugs for Gen 3 bigbodycam05 3rd & 4th Generation (1992–1996 & 1997–2001) 13 12-01-2002 02:14 AM
