Extended oil filter for 2.2L 2000? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-23-2006, 12:23 AM   #1 (permalink)
etc
View etc's Photo Gallery
I need the part number of an extended oil filter for 2000 Camry 2.2L
Something I can provide at Advanced Auto/Autozone or NAPA even.
I've always used Purolator Pure One.
I plan to use Mobil 1 5w20 FWIW to preempt the sludge problem.
etc is offline   Reply With Quote
Old 09-23-2006, 12:36 AM   #2 (permalink)
touringcamry's Avatar
Gameroom cash: $510725
If you want larger filter, look up the filter for 2002 Camry 2.4l
Recommended oil is 5W-30 or 10W-30!! 5W-20 is not recommended by Toyota.
2007 Camry 2.4L 5M
Old 09-23-2006, 01:21 AM   #3 (permalink)
Tom 2000's Avatar
Gameroom cash: $189850
View Tom 2000's Photo Gallery
Use the oil filter for the V6 model. It's the bigger one on the right.
5W-30 is what you want. I've used Castrol GTX, changed the oil every 3000 miles and never had a problem.
Tom
2004 Prius Touring Edition
2003 Corolla Luxel
2000 Camry LE - Lunar Mist Metallic
Tom 2000 is offline   Reply With Quote
Old 09-25-2006, 04:59 PM   #4 (permalink)
View toyomoho's Photo Gallery
Check the owner’s manual for the recommended oil viscosity. 5W-30 or 10W-30 is recommended depending on the air temperature range the car is driven in.
Old 09-25-2006, 09:28 PM   #5 (permalink)
View 68Malibu's Photo Gallery
Do you know if it has an anti-drain back valve (like the 4 cyl does - guessing anyway)? What about some sort of internal pressure relief (4 cyl and 6 have same oil pressure specs?)? Just some thoughts...
68Malibu is offline   Reply With Quote
Old 09-25-2006, 10:50 PM   #6 (permalink)
Tom 2000's Avatar
It's identical to the 4-cyl oil filter (even the price!) except for the size.
I've never had any problems since I started using it.
Tom
2003 Corolla Luxel
Old 09-25-2006, 11:06 PM   #7 (permalink)
No leaking issue even though the gasket is larger?
2007 Camry 2.4L 5M
Old 09-26-2006, 05:30 AM   #8 (permalink)
Tom 2000's Avatar
No problems whatsover.
I didn't think the gasket was any different.
Tom
2003 Corolla Luxel
Old 09-26-2006, 06:35 AM   #9 (permalink)
View Ken4's Photo Gallery
Use the longer one for the 2.4L 2AZ-FE.
The filter for the 3.0L V6 1MZ-FE will not fit.
Ken4 is offline   Reply With Quote
Old 09-26-2006, 08:26 AM   #10 (permalink)
Tom 2000's Avatar
I stand corrected.
I thought the 90915-YZZF1 filter I posted was the oil filter for the V6 (1MZ-FE) model, but after checking, I found that it's for the 2AZ-FE model.
The 1MZ-FE V6 models use 90915-YZZD1.
Well, I had the engine wrong, but I had the filter correct. I'm glad I posted the pic.
Tom
2003 Corolla Luxel
Old 09-26-2006, 09:55 AM   #11 (permalink)
The gasket's ID on the V6 filter is slightly smaller than the OD on the I4, which is why I asked. But since you are not having a problem, it seems like a good solution.
You can find the specs on http://www.wixfilters.com
2007 Camry 2.4L 5M
Old 09-26-2006, 03:23 PM   #12 (permalink)
Gen 4 XLE v6
jhbhatia's Avatar
View jhbhatia's Photo Gallery
Thats exactly what i use for my 5sfe! Never had any problems! Great product!
Edit: Shoud i be using the YZZd1 product?
Desi Toyota Dude Here!!!
jhbhatia is offline   Reply With Quote
Old 09-26-2006, 09:03 PM   #13 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
No.
For a 5S-FE, use 90915-YZZF2 or 90915-YZZF1. YZZF1 is just taller.
YZZF2 replaced YZZA2
YZZF1 replaced YZZA1
"Skoolin' the unlearned!"
Old 09-27-2006, 03:18 PM   #14 (permalink)
Gen 4 XLE v6
jhbhatia's Avatar
^^ thanks, cus all i do is ask for 1mz filters and thats what they give me!
Old 10-01-2006, 11:39 PM   #15 (permalink)
etc
I am confused. So which filter is it? For 5S-FE? 2AZ-FE - and where do I get it? Advanced Auto?
Is anything available on ebay?
WTF! 2007 Camry SE Only Giving Me 263.7 mi WITH Full Tank! LunarMist 5th & 6th Generation (2002-2006 & 2007-2011) 262 01-15-2011 02:17 PM
Remote Oil Filter? Overwork pump? Go 4x 1st Generation (1995.5–2004) 4 02-15-2006 01:26 PM
Toyota Oil Filter has changed (4-cyl) Tom 2000 Camry & Solara Lounge 11 01-04-2006 08:57 PM
Better Oil filter for Camry TRDragoon Camry & Solara Lounge 44 12-08-2003 03:38 PM
Oil Filter Wrench BenG Hardcore Tech and Competition 12 07-22-2003 11:01 PM
